Author Topic: coilover tech  (Read 42036 times)
coilover tech
« on: October 19, 2014, 12:47:48 PM »
so i found a spring rate calulator and goofin with #'s i beleive are close to mine
http://www.crawlpedia.com/spring_rate_calculator.htm
spring rate came out to be  2096 lb/in
it doesnt explain what that transfers(or i cant figure it out) to what primary spring you would use, any advice?
Re: coilover tech
« Reply #1 on: October 19, 2014, 01:20:46 PM »
One ton per inch doesn't sound too likely. Misplaced decimal? 210 doesn't seem terribly unlikely
Re: coilover tech
« Reply #2 on: October 19, 2014, 01:39:11 PM »
oic what i did, its not the deg the shock sits at ,but the deg distance from 90deg. im guessing for the rear possibly 500lbs a corner, gives me a new rate of 80lb/in. so my dual rate would be 80/125?
Re: coilover tech
« Reply #3 on: October 21, 2014, 04:01:35 PM »
negative sir
Re: coilover tech
« Reply #4 on: October 21, 2014, 04:04:13 PM »
125/80?
coilover tech
« Reply #5 on: October 22, 2014, 07:40:19 AM »
I'd check the profender spring calc but that quality app just sits here
Total rate is A/2+B/2 isn't it?
« Last Edit: October 22, 2014, 08:34:36 AM by mr.mindless »
Re: coilover tech
« Reply #6 on: October 22, 2014, 08:08:36 AM »
Re: coilover tech
« Reply #7 on: October 22, 2014, 10:23:05 AM »
for me it comes up at a 80lb primary, but no one makes an 80, so i went up to a 100lb. it says to use a lower that is 20-50 stiffer so i got a 150lb, i coulda went up to 175. so in the end i ordered a 14" 100lb upper, 16" 150 lower
Re: coilover tech
« Reply #8 on: October 22, 2014, 11:09:51 AM »
1/R1 + 1/R2 = 1/Rtotal
Rtotal = 1/(1/R1 + 1/R2)
Rt = 1/(1/100 + 1/150) = 1/ (.01 + .006666) = 60lb/in
you will be soft with too much PL  (if you were shooting for 80 total rate)
80 on a 14" shaft at 50/50, with 2" preload would be 780lbs corner at ride.  F=R *X = 80(7+2) = 780lbs
60 on a 14" shaft at 50/50, with 2" preload would be 540lbs corner at ride.  F=R *X = 60(7+2) = 540lbs
Re: coilover tech
« Reply #9 on: October 22, 2014, 12:17:02 PM »
inverses, fuck me! why can I never remember that??
Re: coilover tech
« Reply #10 on: October 22, 2014, 12:27:46 PM »
its ok, at least you can spell better than me.   ::)
Re: coilover tech
« Reply #11 on: October 22, 2014, 12:35:06 PM »
I have no idea what that nonsense said.
Re: coilover tech
« Reply #12 on: October 22, 2014, 12:44:38 PM »
hahaha
Re: coilover tech
« Reply #13 on: October 22, 2014, 02:41:28 PM »
addition and division sometimes can be hard.
Re: coilover tech
« Reply #14 on: October 22, 2014, 06:56:28 PM »
This made me chuccle a little  :)
