Author Topic: Aussie Locker BRO-LITE  (Read 50871 times)
Re: Aussie Locker BRO-LITE
« Reply #135 on: May 17, 2015, 09:26:04 PM »
Really good progress this weekend.
Keith came out and helped Friday night and then saturday along with the Wingman.
Kicked out a bunch of work.
Front and rear shock mounts are done.
Front shocks and coils along with retainers are installed.
Radiator, shroud and fan are all mounted and ready for coolant and power.
Rear bump stops are complete
All cage and structural tube work is complete minus corner braces around windshield opening.
To do list:
Fuel lines
Complete Fuel cell mount
Fabricate new front brake lines
Install new front brake calipers and rotors
Install new front brake hoses
Fabricate new rear hard brake line to 8.8 axle
Drill and tap axle housing for new vent location (existing was under bump stop pad. Welded shut)
Install 4:88 gears (Prob not gonna happen)
Install AUSSIE LOCKER
charge shocks
Install cherry bomb and support hanger
Run new battery cable to rear mounted battery
Limit straps (cheap insurance)
Bolt doors
Install Window net
Mount fenders (Prob not)
Mount bed sides ( Prob not)
Front and rear bumpers (would be nice)
« Reply #136 on: May 17, 2015, 09:30:41 PM »
EGR Deleted
Air intake moved inside cab and air cleaner done
Factory wiring harness getting trimmed as time allows
« Reply #137 on: May 17, 2015, 11:44:36 PM »
« Reply #138 on: May 17, 2015, 11:45:57 PM »
« Reply #139 on: May 17, 2015, 11:48:37 PM »
« Reply #140 on: May 18, 2015, 08:46:58 AM »
Looks good!
« Reply #141 on: May 18, 2015, 09:09:21 AM »
Torchmate was earning it's keep this weekend.
Between custom rear shock mount parts to random tabs and gussets. Custom fuel cell mount. tube caps and tube clamp/plates.
RGE will be happy this month I'm sure.
« Reply #142 on: May 18, 2015, 03:50:30 PM »
I like that blade on the wall!
« Reply #143 on: May 19, 2015, 01:00:51 AM »
Tonight's progress:
Fuel system plumbed
Fuel pump mounted
Rear brake lines installed
Remote battery cable run
Cherry bomb installed
Temp Power to fuel pump
Got the engine to turn over but no start.
Spent the last few hours tracing wires and double checking things.
Called it quits at 1230
I removed steering wheel and column and opted for stand alone ignition system.
Hopefully I'm just tired and just missing something stupid.
According to my Hayes manual diagrams I have power in the right places.
Ugggh! SO CLOSE!
« Reply #144 on: May 19, 2015, 08:00:25 AM »
After reading Smikes post about deterioration of the cell foam I'm thinking maybe I should confirm I'm getting fuel to the engine first.
« Reply #145 on: May 19, 2015, 09:05:05 AM »
do you have the two wires for impact detection thing connected together? not sure if it talks to ecm or just kills power to fuel pump
i used OEM fuel pump control
« Reply #146 on: May 19, 2015, 09:16:06 AM »
I believe that's just in-line with fuel pump wiring. Give that like 70% confidence since it's something I think I've heard.
Not that it really matters which it is, as long as it's bypassed.
« Reply #147 on: May 19, 2015, 10:21:20 AM »
I have fuel pump wired direct to new switch panel.
But did not re connect impact sensor.
Not sure where it is yet.
It may shut off ecm.
That's definitely describes symptoms.
Fingers crossed for later tonight.
« Reply #148 on: May 19, 2015, 11:25:02 AM »
In front of passenger footwell.
« Reply #149 on: May 19, 2015, 03:50:27 PM »
Yup.
cab is completely stripped out of all wiring.
Just need to find it in the rats nest.
