Author Topic: brolite cherry pop 573  (Read 84051 times)
Re: brolite cherry pop 573
« Reply #45 on: October 28, 2014, 11:37:06 AM »
All show no go :)
It'll scream with 30-32s though!!
« Reply #46 on: November 02, 2014, 12:47:26 AM »
caged out in 1 day!
« Reply #47 on: November 02, 2014, 07:54:05 AM »
Dam your good
« Reply #48 on: November 02, 2014, 11:48:01 PM »
ready for shocks / plumb / wire.
harness mounts and cell mounts done.  rear shocks removed.
« Reply #49 on: November 03, 2014, 07:41:15 AM »
Looking good
« Reply #50 on: November 04, 2014, 11:59:15 PM »
put on the lift tonight
front shocks removed
front firewall trimmed and beat in
2" lift spacers installed
2" lift spacers removed, not going to work.
tony
  • Come and take it
« Reply #51 on: November 07, 2014, 12:15:23 PM »
What's wrong with doing a taller spring
« Reply #52 on: November 07, 2014, 10:23:34 PM »
Camber all f'd up
« Reply #53 on: November 08, 2014, 02:19:22 PM »
TTB  will do that unless you change the pivot points or turn the beams.
« Reply #54 on: November 17, 2014, 10:53:05 AM »
ran my test loop around the shop property!  this is going to be too fun
needs a clutch or something.  no clutch now bah.
« Reply #55 on: November 17, 2014, 01:08:09 PM »
Def gonna be fun.
My wife's hot laps after taking it off the trailer involved a low limb on our Japanese maple tree and the contractors cap.
Passenger seat is on the list
« Reply #56 on: November 23, 2014, 10:35:37 PM »
looks like when the coil popped out after bajaing into the kitchen hauler the tire ripped off the clutch resivior nipple.
i temporarly tapped and fixed, but cant get the clutch to bleed.
looks like the trans is coming out the put all new parts in.  bah!
« Reply #57 on: November 24, 2014, 05:18:13 AM »
Bummer. Broken before the first race!
« Reply #58 on: December 14, 2014, 08:12:01 PM »
what do i need to fix the clutch in this pile?
i cant get it to bleed out with my hack fix.  forums say you have to pull the master from the firewall and tip it to bleed air.
is there a fully bleeded assembly to swap in?
pull the trans and swap clutch and all?
« Reply #59 on: December 14, 2014, 09:17:12 PM »
I have a syringe you can try and back bleed it..
