Author Topic: Brandy new 4500 Cummins  (Read 251108 times)
Re: Brandy new 4500 Cummins
« Reply #240 on: July 07, 2015, 07:55:28 AM »
As long as it actually does blow up within warranty...
« Reply #241 on: July 07, 2015, 08:40:05 AM »
wont own it for more than 3-4 years
« Reply #243 on: July 11, 2015, 02:40:23 PM »
Ram forums told me the see dealer now for fuel system service message is lynced with calculated fuel filter life.
Changed oil and filter, Chassis fuel filter/water separater, under hood cartridge filter (67$ from Dealer with delphi discount), and greased everything.
holding off on rear diff fluid service.  just beat after fluids and trying to tighten up my goose ball nut.  apparently its been loose and beating it self.  cant loose or tighten it, so i just welded it to the mount.  \
now own next group of big boy sockets past the 3/4 HF set.
oil and fuel monitors reset, 2 DEF engine codes cleared 14940 miles
« Reply #245 on: July 14, 2015, 09:33:11 AM »
I still cant cross into WIX.. funny
« Reply #246 on: August 24, 2015, 10:19:27 AM »
got a plan for some flat bed extensions to drive buggy or a jeep on.  Gona maybe grab some steel at lunch.  Been thinking about this for a while and have a solid plan.
« Reply #247 on: August 24, 2015, 03:43:34 PM »
That'd be an awesome sight.
« Reply #248 on: August 24, 2015, 04:11:40 PM »
Think that idea would work on a '42 LM?
I know a guy with one ...
« Reply #249 on: August 24, 2015, 05:32:58 PM »
the bed is 9'6" long already, just going to make some 3' or so extensions or so, and with some 6-7' ramps they will all make stake sides for scraping too.
no idea what a 42' LM is
« Reply #250 on: August 24, 2015, 06:01:32 PM »
It's a 1948 LM (Load Master), not a 42, as mr wing pointed out privately.
« Reply #251 on: August 24, 2015, 06:32:11 PM »
Good idea on using the ramps as stake sides. Is that what Miller did with his F550? I remember seeing his sides and thought they looked odd.
« Reply #252 on: August 24, 2015, 08:51:53 PM »
yup, he did
« Reply #253 on: August 24, 2015, 11:41:24 PM »
maybe half done.  some tube supports and then tack up the ramps that are cut out.  then stake side provisions.
« Reply #254 on: August 26, 2015, 12:15:37 AM »
ready for load test tomorrow in day light!
ramps have stake side stows, extensions bolt on with ten 3/8" bolts the little dewalt makes short work of in 2 min.
