Author Topic: Shop  (Read 28289 times)
Shop
« on: September 09, 2014, 08:51:05 AM »
I'm looking at some shop space I'll probably rent in the city. Only issue is it has a brand new concrete floor and owner says no drilling the floor. The compressor needs to be secured down but I figure I can just put it on a 3'x3' piece of plate and weld some bolts sticking up to secure it. The issue is I was pretty set on installing a 2 post lift.
Options would be something like this http://rochester.craigslist.org/for/4587143288.html but obviously no good for suspension work / tires / brakes.
So was playing with the idea of how to support a lift without drilling the floor. Would need structure supports top and bottom between the posts. and legs that extend front and back. thoughts?
Re: Shop
« Reply #1 on: September 09, 2014, 09:13:34 AM »
you and a new floor that's not suppose to be damaged sounds like a bad idea
Re: Shop
« Reply #2 on: September 09, 2014, 09:27:28 AM »
this place?
http://rochester.craigslist.org/prk/4648746112.html
whats the electric and heat situation?  looks nice ceiling height for a lift.
Re: Shop
« Reply #3 on: September 09, 2014, 09:28:04 AM »
My compressor is still on a pallett.
Not sure about a lift that's not attached to the floor.
Seems like I'd keep searching for a older floor.
Re: Shop
« Reply #4 on: September 09, 2014, 09:40:10 AM »
seems like this would be what i need.
location sucks
http://rochester.craigslist.org/off/4658636624.html
Re: Shop
« Reply #5 on: September 09, 2014, 09:41:41 AM »
I'd pass on location, shithole part of goodman
Re: Shop
« Reply #6 on: September 09, 2014, 09:46:15 AM »
yes that one. Best price for size I've found so far. Location is fine with me.
He said he would run 220 to the garage for $425 per month. I have a buddy who is throwing in $150 a month. its 22 wide by 28 deep, so not really 2 deep in terms of being able to work on stuff.
roof slopes downward side to side. where left side is tall at ~14 and right side is ~10. which actually works ok since the left bay door is larger so is conducive to that being the main work area.
electric included. no heat. my salamander would heat the area fine.
Re: Shop
« Reply #7 on: September 09, 2014, 09:48:02 AM »
location sucks
in the HOOD.
but a consideration if its "drive up and drive in" kinda place. too far for you though.
Re: Shop
« Reply #8 on: September 09, 2014, 09:51:52 AM »
location sucks
in the HOOD.
That's in a commercial complex behind Charlotte appliance, not bad at all, cameras on the buildings ,might of been a skatepark in there at one time
Re: Shop
« Reply #9 on: September 09, 2014, 09:52:12 AM »
x2 billionty
My horizontal compressor sits on a couple of 2x4s.  It'll be fine.
Re: Shop
« Reply #10 on: September 09, 2014, 09:52:44 AM »
You're right. Father north than I though.
Re: Shop
« Reply #11 on: September 09, 2014, 09:53:51 AM »
Could build a steel platform with enough structure to support loading front/back and side/side...
Re: Shop
« Reply #12 on: September 09, 2014, 09:58:14 AM »
Something to consider is the surrounding area.
If it's a residential area they won't be happy about an after hours fab / repair shop making noise. Business use or not!
don't sign anything more than a month to month lease.
Re: Shop
« Reply #13 on: September 09, 2014, 09:59:24 AM »
location sucks
seems like you could buy for that price instead of renting
Re: Shop
« Reply #14 on: September 09, 2014, 10:51:32 AM »
is this the norm for "commercial" space? we actually have not discussed lease at all. I will ask owner what he expects.
This was my thought.
