Author Topic: bro lite revolution  (Read 146573 times)
Re: bro lite revolution
« Reply #435 on: April 26, 2016, 02:25:20 PM »
FYI
Will called around shopping for springs and found this info:
2wd ranger
rough country 1.5" leveling springs
4 cly 445 spring rate
6 cyl 480 spring rate
superlift
1-2 lift spring 6cyl, 3" in a 4 cylinder
448 spring rate
« Reply #436 on: April 26, 2016, 02:37:28 PM »
would love to know what stock 5.0 explorer is to compare since that might be used/JY-able.
« Reply #437 on: April 26, 2016, 03:02:02 PM »
my explorer springs were 67$ shipped for the pair, not worth hassel for rotten JY springs.
« Reply #438 on: April 26, 2016, 03:16:52 PM »
true! would still be nice to put a number to them. should be able to do the math if they aren't progressive. Just need exact # active coils and coil dia.
« Reply #439 on: May 05, 2016, 08:31:28 AM »
Smike where did you post the wiring harness pinout?
« Reply #440 on: May 05, 2016, 09:17:46 AM »
« Reply #441 on: May 05, 2016, 05:50:27 PM »
Thanks can't navigate for crap in Tapatalk
« Reply #442 on: May 16, 2016, 11:48:51 AM »
we  need to step up testing on these units.  continual failure for stupid things.  getting annoying.
« Reply #443 on: May 16, 2016, 01:50:18 PM »
i was curious how fast i was going on the straight before the step up jump
2nd gear is 2.2 or 2.25 depending on which Manual 5 speed, 4.10 gears, read line is 6250 from the factory, 26.7" diameter tire (215 70 r15)
thats 55.1mph  (wheel speed)
i was bouncing off the rev in 2nd just about 2 truck lengths before the jump consistently after failing to gain anything from shifting to 3rd.
« Reply #444 on: May 16, 2016, 01:53:50 PM »
I was hitting 55-60 in second at jeffs. Not sure how accurate that is with the tire change but I expect within 15%.
Was hitting 50 before the lane change into the jump whose video I posted
orange anchor
« Reply #445 on: May 16, 2016, 02:09:09 PM »
let's build track X
« Reply #446 on: May 16, 2016, 02:29:18 PM »
I'll build track X in 2 hrs on a week night in my spare time to watch you guys break your trucks as entertainment
fixed it for you jeff
« Reply #447 on: August 17, 2016, 02:47:24 PM »
whats the word on shocks
looks like my fox contact doesnt work at fox any more.
chris doesnt work with wayne anymore and i dont think they do shocks much any more
sent Tim at altech a txt today
no responce from Erik or Decker via txt
what was the last ADS quote for what erik has? or without adjustors
« Reply #448 on: August 17, 2016, 04:12:18 PM »
wayne can still build.  maybe fox got there inventory out of their ass by now
Mike you want a quote for a pair of 10"s and a pair of 12"s too?
« Reply #449 on: August 17, 2016, 04:38:53 PM »
I haven't had time to hound Decker.
May as well go ADS and stay consistent, I'm pretty mad at Fox for jerking everyone around on inventory and i've already gone elsewhere for the more important units.
