Author Topic: Gif Built Buggy  (Read 98709 times)
tony
  • Come and take it
Re: Gif Built Buggy
« Reply #285 on: December 28, 2014, 12:43:39 PM »
Nice
Re: Gif Built Buggy
« Reply #286 on: December 28, 2014, 02:59:39 PM »
thats a big bar for that roof!
Re: Gif Built Buggy
« Reply #287 on: December 28, 2014, 09:33:11 PM »
ya,    i need to put some protection around it.  mostly to keep the trees off it
Re: Gif Built Buggy
« Reply #288 on: December 29, 2014, 04:22:52 PM »
light bar protection install complete
« Last Edit: December 29, 2014, 09:35:58 PM by gif »
Re: Gif Built Buggy
« Reply #289 on: July 21, 2015, 06:41:45 PM »
found a cracked rim after my last outing at RC   :o
Re: Gif Built Buggy
« Reply #290 on: August 02, 2015, 10:57:15 PM »
Planned upgrades for this pig:
1) PSC Power Steering Pump -  1500 PSI / High Flow
factory pump is dying/dead     cant find a good source for the P185 pump
figured its time to step it up
http://www.polyperformance.com/PSC-80-Up-Dodge-GM-Hi-Performance-P-Pump-w-o-Remote-Feed-Can
2) Stewart Stage 1 High Flow water pump and High Flow 180 thermostat
Looking for better cooling on full throttle assaults.
may also incorporate electronic thermostat to engage high speed cooling fan
http://stewartcomponents.com/index.php
Flow in GPM (Gallons Per Minute)
RPM    Competitors Pump    Stewart Stage 1
1000    17                              18
1500    25                              32
2000    34                              42
2500    42                              55
3000    51                              65
3500    59                              77
4000    68                              90
4500    76                            101
5000    85                            112
5500    93                            122
6000    102                            132
6500    110                            138
7000    119                            148
7500    127                            157
8000    139                         158
3) New 1-1/8" bore, brake master cylinder for more volume.  ( less pedal travel )    was 1" bore
also adding mechanical stop to brake pedal to stop pedal stroke before bottoming out master cylinder bore.
i have found that in a panic stop situation the brake booster allows for enough force to bottom out the master cylinder.
4) heat shield to block heat soaking from coolant fan blowing on the fuel cell.
only a small part of the cell is exposed to the fan,   however i have noticed a pressurized fuel cell spitting gas out the vent tube.
All parts sitting on the work bench.
« Last Edit: August 03, 2015, 11:07:00 PM by gif »
Re: Gif Built Buggy
« Reply #291 on: August 03, 2015, 07:58:43 AM »
Sounds good.
Question about brake system volume?
Can you achieve more volume to the calipers by increasing brake line diameter?
Or swapping in 1/2 ton calipers on the 60?
Re: Gif Built Buggy
« Reply #292 on: August 03, 2015, 09:25:44 AM »
brake line diameter doesn't mean anything.  some claim excessive flex line or low quality rubber line eats up volume because of bulge.
smaller diameter pistions on the calipers would be more travel but less force.  i changed to 1/2 on the 60 front and dont see a difference.  i do notice my rear brake pads are wearing 4X as fast as front.
Re: Gif Built Buggy
« Reply #293 on: August 03, 2015, 01:46:21 PM »
What is more efficient in a hydralic brake system?
Velocity or volume?
Smaller lines should flow less volume but more line pressure?
And vice Versa?
Just curious.
Need to address 2 pumps necessary on buggy system.
Re: Gif Built Buggy
« Reply #294 on: August 03, 2015, 02:02:09 PM »
forget about efficient and velocity.  a braking system is basically a static system in our use.  yes there are things like heat and cavitation but ignore that for now....
pressure is Force / area is all you need to know.  with a MC, you have stroke and bore.  we run E350 MC that have 1 3/8" bore and about 1/2" longer stroke than the corvette MC.  your brake pressure is determined by petal force / bore area... your stroke x bore area is your volume you can push at that pressure to your calipers.   There are many "areas" you can adjust to change any of these things.   bore, stroke, petal geometry, caliper sizes, booster or non booster, ect.
Hose diameter does not effect any of these things (negligible).  a 3/16 dia brake line has more than enough volume to work on any of our systems with out causing restrictions that would slow up "petal feel" or create excessive heat.
2 pumps? are you talking fuel now?
CJ
Re: Gif Built Buggy
« Reply #295 on: August 03, 2015, 02:26:04 PM »
Our buddy DJ hay a hydro boost system, it's sick. Can lock up all 4 40's at any speed.
Re: Gif Built Buggy
« Reply #296 on: August 03, 2015, 05:47:58 PM »
If you have to pump the pedal you have pads backing off for some reason (warped rotor, loose wheel bearing, sloppy slides) or trapped air.
Re: Gif Built Buggy
« Reply #297 on: August 03, 2015, 06:12:13 PM »
you have a part number for that E350 MC?
Re: Gif Built Buggy
« Reply #298 on: August 03, 2015, 06:34:40 PM »
i have a corvette 1 1/8 bore MC
Going to try to get Dorman M39324 which is chevy 1.25" bore
or M390530 which is ford 1.375" bore
found cardone 10-1584 with a 1.330 bore for 24$ at advance
gona try it.
Re: Gif Built Buggy
« Reply #299 on: August 03, 2015, 08:28:27 PM »
cast 2229071   101584 (reman)  131584 (new) — 1986-74 CHEVROLET/GMC TRUCKS
Bore 1.3125
thats a nice find
might try that next
gona try it.
« Last Edit: August 03, 2015, 08:43:27 PM by gif »
