Author Topic: Gif Built Buggy  (Read 98697 times)
Re: Gif Built Buggy
« Reply #240 on: June 27, 2014, 03:05:35 PM »
old front drive shaft was at its limits.
this is a d44 pinion stub i used when i made the first shaft.  about ready to pop...
« Last Edit: June 28, 2014, 12:58:34 PM by gif »
Re: Gif Built Buggy
« Reply #241 on: June 28, 2014, 01:30:24 PM »
front 60 pinion bearing looks a little loose.
« Last Edit: June 28, 2014, 01:38:56 PM by gif »
Re: Gif Built Buggy
« Reply #242 on: June 28, 2014, 09:25:32 PM »
Those tires are hooking up well!
Re: Gif Built Buggy
« Reply #243 on: June 28, 2014, 10:34:55 PM »
details of front axle just for giggles?
was it 4.10's as found or did you build it for the buggy build?
Re: Gif Built Buggy
« Reply #244 on: June 28, 2014, 11:36:19 PM »
Was 4:10.
Re: Gif Built Buggy
« Reply #245 on: June 28, 2014, 11:45:15 PM »
Smike do you spin down your 14b yokes to 2" ?
Re: Gif Built Buggy
« Reply #246 on: June 29, 2014, 12:04:16 AM »
no, but a 14 bolt pinion with the gear cut off is a light pres inside 2" x 120 wall dom- fine for a protected shaft- like on 571
572 rear mid shaft is 2" DOM with 1.75x250 wall dom pressed insided
Re: Gif Built Buggy
« Reply #247 on: June 30, 2014, 01:10:09 PM »
this is a D60 pinion I machined to fit my pillow block bearing.  This will allow me to use a 1350 yoke.    i figure this is the weakest point in my driveline now.
« Last Edit: July 10, 2014, 08:20:48 AM by gif »
Re: Gif Built Buggy
« Reply #248 on: June 30, 2014, 01:17:53 PM »
what size carrier bearing is that? 1.25"?  is it solid flange or hollow?
matt broke a hallow flange 2" on chocolate thunder   8)
Re: Gif Built Buggy
« Reply #249 on: June 30, 2014, 01:22:14 PM »
Because it was solid mounted, duh! Haha
Re: Gif Built Buggy
« Reply #250 on: June 30, 2014, 01:29:13 PM »
solid stainless pillow block with steel bearing.  yes 1.25"
Im more worried about the pinion. I wonder if i weakened it with the machine work.  But i figure its the same as whats in the axle...
« Last Edit: July 01, 2014, 08:22:38 AM by gif »
Re: Gif Built Buggy
« Reply #251 on: July 01, 2014, 09:24:09 AM »
i was wondering the same.  my band saw just sits and pollishes a pinion if you try to cut it.  have to use a cut off wheel.  you must have used some carbide serous tools on a lathe to cut the case harness off
Re: Gif Built Buggy
« Reply #252 on: July 01, 2014, 09:24:58 AM »
i bet your fine, the welding we do to the OD any way probably destroys the integrity of any added heat treat
Re: Gif Built Buggy
« Reply #253 on: July 09, 2014, 06:36:07 PM »
Re: Gif Built Buggy
« Reply #254 on: July 09, 2014, 09:16:58 PM »
