Author Topic: Gif Built Buggy  (Read 98710 times)
Re: Gif Built Buggy
« Reply #150 on: May 04, 2013, 01:07:14 PM »
Broken rear CV
both Joints and the H broke
Re: Gif Built Buggy
« Reply #151 on: May 04, 2013, 01:13:48 PM »
Driveshaft Universal Joint Dimensions and Torque Ratings
Series    Cap-to-Cap     Diameter    Continuous    Short-Term Max    Deformation Max    Angularity
1310         3.22                 1.08               130lbs-ft         800lbs-ft                 1,600lbs-ft                  30o
1330         3.63                 1.08               150lbs-ft         890lbs-ft                 1,850lbs-ft                  20o
1350         3.63                 1.19               210lbs-ft         1,240lbs-ft                 2,260lbs-ft                  30o
1410         4.19                 1.19               250lbs-ft         1,500lbs-ft                 2,700lbs-ft                  27o
Re: Gif Built Buggy
« Reply #152 on: May 04, 2013, 09:42:05 PM »
Transmission is out.    (9 HR job  >:()
Going to talk to my tranny builder and see what upgrades I should do.
« Last Edit: May 04, 2013, 11:10:50 PM by gif »
Re: Gif Built Buggy
« Reply #153 on: May 04, 2013, 10:09:55 PM »
You should talk to your chassis builder as well. 9 hours to get the motor and trans out is a little annoying. :)
Re: Gif Built Buggy
« Reply #154 on: May 04, 2013, 11:25:55 PM »
A lot annoying
But my fault for thinking a Craigslist tranny would be "ok".
Re: Gif Built Buggy
« Reply #155 on: May 16, 2013, 08:23:55 PM »
Tranny upgrade list: rated to 650hp and 600 ft lbs of torque
Towing rebuild kit
Heavy Duty "Beast" Sun Shell
Corvette 2nd and 4th Gear Servo
Upgraded reverse boost valve
Alto red eagle red band
Sonnax pinless accumulators
5 pinion planets from a denali series 4l65e
10 or 13 vane pump upgrade
29 Element Sprag
« Last Edit: June 01, 2013, 10:42:52 PM by gif »
Re: Gif Built Buggy
« Reply #156 on: May 17, 2013, 05:06:36 PM »
Re: Gif Built Buggy
« Reply #157 on: May 17, 2013, 05:07:42 PM »
Re: Gif Built Buggy
« Reply #158 on: May 19, 2013, 07:53:47 PM »
Re: Gif Built Buggy
« Reply #159 on: June 01, 2013, 10:19:06 PM »
My junk yard search was a good one.
I scored a Ford Super Duty front driveshaft and a front shaft from a late 80's blazer.
The Ford shaft is a great source for 1 ton parts.
First, the CV is a true Spicer 1350.  Next the Slip yoke is also a 1350 with a 1.5" 16 spline.
For my use I need to mod the flange to mate to the stock 241 output flange.
« Last Edit: June 01, 2013, 10:44:14 PM by gif »
Re: Gif Built Buggy
« Reply #160 on: June 01, 2013, 10:23:59 PM »
The R3 GM is on the right.
The Ford center hole is only 2".    So I had to open it up to the GM 3.125"
Re: Gif Built Buggy
« Reply #161 on: June 01, 2013, 10:24:44 PM »
Ford before and after pic
GM 241 Output flange.
« Last Edit: June 01, 2013, 10:45:43 PM by gif »
Re: Gif Built Buggy
« Reply #162 on: June 01, 2013, 10:27:27 PM »
Here are the rest of the ford parts.
Re: Gif Built Buggy
« Reply #163 on: June 01, 2013, 10:42:12 PM »
The blazer front shaft is a 1/2 ton CV 1310. The drive shaft I broke uses this style.
On my driveshaft the slip yoke is a Ford 1350  with a 1.5" 16 spline and uses 1/4" wall tube.
I rebuilt this shaft to have as a spare.   This time I used Spicer 1310 non greasable u-joints.
I could see obvious break points at the grease fittings on the joints that blew apart.
 I know it will hold up to a lot of abuse, however I wont trust this shaft for crazy heavy use as I have learned...
« Last Edit: June 01, 2013, 10:47:34 PM by gif »
Re: Gif Built Buggy
« Reply #164 on: June 02, 2013, 07:41:50 AM »
Nice work!
