Author Topic: large hole saw  (Read 1306 times)
large hole saw
« on: May 07, 2014, 10:39:28 AM »
before I buy one..
Anybody have a 6.5 or 6.75" hole saw?
Re: large hole saw
« Reply #1 on: May 07, 2014, 10:49:29 AM »
thats a wrist breaker!
Re: large hole saw
« Reply #2 on: May 07, 2014, 10:56:39 AM »
5" is as big as i go.
tail lights i assume?  i use a cutoff wheel and the plasma
Re: large hole saw
« Reply #3 on: May 07, 2014, 11:27:38 AM »
speakers...
although.. I do have a 4" from the light son the YJ..
unsure what I'm doing with the CJ.
Re: large hole saw
« Reply #4 on: May 07, 2014, 11:36:27 AM »
Jig saw/ body saw/ plasma > broken wrists and broken pilot bits
Re: large hole saw
« Reply #5 on: May 07, 2014, 12:02:24 PM »
high speed girl drills break wrists.
man and man drill do work.
Re: large hole saw
« Reply #6 on: May 07, 2014, 01:39:48 PM »
ive never had a problem with a hole saw..
slow and steady, lots of lube and a gentile trigger...
works in the bedroom also
Re: large hole saw
« Reply #7 on: May 07, 2014, 02:02:39 PM »
try that method hawgin through 8 stacked 2x8's footer
Re: large hole saw
« Reply #8 on: May 07, 2014, 02:04:31 PM »
have a water cooled diamond core saw for that...
needed to run some exhaust in the house...
100 yr old Tudor built like a Sherman tank!
in just drilling some holes in aluminum for speakers and possibly lights.
Re: large hole saw
« Reply #9 on: May 07, 2014, 02:26:27 PM »
a diamond bit through wood?
Re: large hole saw
« Reply #10 on: May 07, 2014, 02:37:43 PM »
no.. foundation and stone/stucco..
new boiler and some shower exhaust fans..
but it did make short work of the plaster/lath/steel mesh
Re: large hole saw
« Reply #11 on: May 07, 2014, 03:12:44 PM »
I used to cringe when I had to drill (2) 4-1/2" holes for furnace vents through the old farm houses in mendon & pittsford.  That old wood is no joke!
Re: large hole saw
« Reply #12 on: May 08, 2014, 07:25:10 AM »
I almost severed an artery drilling our trailer for side access cover for RV plug couple years back.
Steel skin , plywood and steel studs... no consistency there.
 then again I was in the reverse Cloverfield position. So i most likely deserved it walking across my arm like it did.
Gotta respect a hole saw!
