Author Topic: D44f & HP-D60r Axles for CJ-7 - Chromoly shafts & Locked  (Read 1398 times)
« on: January 05, 2014, 12:48:04 PM »
Front:
Dana 44
From a IH Scout II, Passenger Drop, long side is narrowed for CJ-7 width, Aussie Locker, Chromoly shafts, Spare stock shafts, Disk brakes, New wheel bearings, New Calipers, New Pads, New Warn Premium lock-out hubs, extended stainless steel brake lines, Ruff Stuff Chromoly heim joints with .250 wall drag link & tie rod. 4:10 gears, setup for spring under suspension. Have run both 2" and 2.5" front leafs w/ same setup.
Rear:
Dana 60 High Pinion
Fabricated From a Ford front dana 60. This Axle Was Custom Built by Mitchell Differential for CJ-7 width, spring under. 35 spline Chromoly shafts, Detroit locker, Cadillac Bonneville disk brakes w/ e-brakes. 4:10 gears, used with spring under suspension setup.
Included with sale is the Heavy duty U-bolt flip kit.
$2400.00
Delivery Negotiable
Located in Victor, NY
Both axles originally built by  Mitchell Differential
"At Mitchell Differential we specialize in building custom differentials such as Dana 44 ... Mitchell Differential, Inc. is based in Shrewsbury, MA which sits in Central Mass"
384 Hartford Turnpike, Shrewsbury, MA 01545
(508) 754-6502
« Last Edit: January 05, 2014, 03:49:45 PM by JEEPWERX »
Re: D44f & HP-D60r Axles for CJ-7 - Chromoly shafts & Locked
« Reply #1 on: January 23, 2014, 07:21:08 AM »
55.5" rear wms -wms
56.5" front (not including the 1.25" spacers currently installed)
Also...
1310 yokes (U-bolt style)
« Reply #2 on: January 23, 2014, 07:22:23 AM »
$2200.00
Free delivery in Monroe / Ontario
« Reply #3 on: February 11, 2014, 06:28:36 PM »
Sold
Delivering to Binghamton this Saturday.
Anyone got anything going or coming that area?
