Author Topic: M4 Ball Joint press  (Read 8237 times)
Re: M4 Ball Joint press
« Reply #15 on: December 07, 2013, 09:31:00 PM »
found it!
« Reply #16 on: December 10, 2013, 08:43:53 PM »
« Reply #17 on: December 10, 2013, 08:52:20 PM »
I built this one real quick just to get the job done.
The HF pos bent on the first ball joint. >:(
I have a sketch of how I will build the "good" one.
Basically telescoping sides.    1.5" X .25 wall inside 2" X .25 wall outer  with through holes for bolts to set the over all length.
2.5" X 2"  I beam top and bottom.     captured top to hold the jack in place while you load the cups on the ball joint.  EZ  :)
« Reply #18 on: December 10, 2013, 08:59:36 PM »
and yes even 6 ton jack is too small.   I stalled mine.   :o
I think a 12 ton with a screw top would be perfect.    Maybe even air/hydraulic...
"stop it brain...   dont make me drink more beer"
« Reply #19 on: December 10, 2013, 10:08:48 PM »
Duramax got some love!
« Reply #20 on: December 10, 2013, 10:38:14 PM »
Yup.     New front Calipers/Rotors/Pads/Lower&Upper Ball Joints.
