Author Topic: '02 TJ with i4 -- Mid Life Crisis  (Read 104018 times)
« Reply #300 on: December 27, 2013, 11:19:31 AM »
Completely agree with everyone. Thinking out loud more than anything. Notice that I'm expecting trail repairs. I'm actually enjoying a bit of the torture of learning this much about MLC. Prior to MLC I wouldn't have changed my own oil, let alone ordered what I need to do things like diff fluid, tuneup, etc.
But there is a point where spending money needs to be done smartly. As Nick said, why drop $200 on a d35 locker and $100 on used spares, when I could get a stronger platform for the same price (less install and perches)? Alternatively, $200 for an Aussie, find a c-clip eliminator, and I could likely get full locked rear without the c-clip trail repair hassel. Probably for less than it would cost me to have sMike put an open 8.8 under MLC.
If it sounds like I'm indecisive, it is because I am. Is locked rear of more value than getting 4.56 gearing to keep 33s on year round? Where do long/adjustable control arms come in? New tires? I'm kind of getting to the point where, especially since I have lots of spare d35 parts, I should leave it open and wait on the axle swap until I've hit some bigger issues. Like gears, DW, and tires.
At least that's what I'm thinking for this 3 minute window.
« Reply #301 on: December 27, 2013, 11:22:49 AM »
I just figured it would be a good candidate because I thought I saw him talking about a re-gear before anyway and I didn't think it was a whole lot of money for a proper width 44.
Thanks for pointing it out. It is a great deal on a 44. about 2 months ago I would have already been arranging to pick it up. For me this discussion is more about prioritizing the next several things that need done, one of which is coming to grips with the d35 limitations.
« Reply #302 on: December 27, 2013, 11:25:44 AM »
Mike wolf still bombs around on a chromo'd D35?  whats that cost these days?
6-8hrs of labor to burn an 8.8 to a TJ plus the Artec swap kit may not be economical when paying out to have it done when you havent broken what you have yet.
« Reply #303 on: December 27, 2013, 11:38:35 AM »
Brand new chromo are < $170/side but go up fast. I've found used steel for $50/set from recyclers. Stock from Napa are $150.
I have two full sets of stock shafts sitting in my barn.
« Reply #304 on: December 27, 2013, 11:39:33 AM »
And if I recall he's locked in the rear. Aussie I believe. I could be wrong.
« Reply #305 on: December 27, 2013, 12:06:15 PM »
i think he is 4.56 detroit locked but not sure on the locker
« Reply #306 on: December 27, 2013, 12:06:30 PM »
Good points by all,
Just buy Moose and go wheeling.  ;D
« Reply #307 on: December 27, 2013, 12:26:55 PM »
the only way I get moose today is to paint it pink with green polka dots. Which is Mrs' way of saying "no".
« Reply #308 on: December 27, 2013, 01:49:05 PM »
i can paint it for you......... :o
« Reply #309 on: December 27, 2013, 02:01:30 PM »
That'd be pretty sweet. Would look good with the mule!
« Reply #310 on: December 27, 2013, 03:06:59 PM »
I said "Sure, I'm sure they'd do that for you just to see me drive it"
That's when she suggested that the couch would be a good place for me to spend some time. I got the message.
« Reply #311 on: December 31, 2013, 08:49:07 AM »
@#$%ing driveshaft squeak started on my way in. Same "precursor" sound that I had a rausch before the CV blew up. No fun has been had since the rebuild. I did hose off salt over the weekend. What should I be looking at to make sure I'm not doing something stupid (and to avoid another rebuild)?
« Reply #312 on: December 31, 2013, 08:51:18 AM »
Probably not the same joint.
« Reply #313 on: December 31, 2013, 08:57:09 AM »
All the joints between the t-case and the diff were replaced. Squeak is coming is in the back of vehicle. Only occurs under load. I would expect wheel bearings to make noises with any rotation. No?
« Reply #314 on: December 31, 2013, 09:03:57 AM »
1) check your fleetpride bill to see if they actually did do both ends
2) do it in 4x4?
3) pull front shaft
