Author Topic: '02 TJ with i4 -- Mid Life Crisis  (Read 119560 times)
« Reply #150 on: October 28, 2013, 10:16:21 AM »
I used a company, they came to my house and did it.  It may have been safelite.  Your welcome for all this help :)
« Reply #151 on: October 28, 2013, 10:23:00 AM »
Most places have a mobile service.  Just a matter of calling and setting up an appointment.  May take a day to get the glass...
« Reply #152 on: October 28, 2013, 10:36:34 AM »
DubT had a gasket issue that resulted in a rotten windshield frame. Not sure of root cause or company.
« Reply #153 on: October 28, 2013, 10:39:47 AM »
just an FYI on windshield frame replacement...
as mike said.. if you have rotted or rusted windshield frame they may not replace if they can’t guarantee safety or a good seal..
simple glass ends up needing a new windshield frame…  if that’s the case..
Jeepglass.com
shipped as a bolt on unit.. in body match color
« Reply #154 on: October 28, 2013, 10:46:50 AM »
No rust that I can see. I think the frame may be a replacement. I'll triple check before scheduling with anyone.
The hinges though... Those need some cosmetic help.
« Reply #155 on: October 28, 2013, 11:46:07 AM »
I used Mr glass before and turned out good and real cheap. It's like another $20 to have them come to you instead of bringing the vehicle to them
« Reply #156 on: November 01, 2013, 01:56:12 PM »
Mike (m4wd mike),
I have developed a squeak in the drive train with the following characteristics
* Only present when transmission is in gear and clutch is out.
* Higher RPM increases rate of squeak.
* If drive train "pressure" is removed (let up on gas, disengage clutch) squeak vanishes.
I first noticed it at Rausch. It went away until about 3 days ago. Now it is constant and present in all RPM ranges. I can't find it with the car up on jacks. Any suggestions before I drop it off on your doorstep?
« Reply #157 on: November 01, 2013, 02:00:51 PM »
sounds like a drive shaft ujoint is dry
« Reply #158 on: November 01, 2013, 02:17:13 PM »
If any of those are CV joints, they are better squeakers if the center pin dries up. not sure if any are CVs on that unit, I'm thinking no
« Reply #159 on: November 01, 2013, 02:22:48 PM »
front shaft, tcase end should be a double cardan. yes, those love to dry up.
can pull the front shaft to trouble shoot that.
« Reply #160 on: November 06, 2013, 06:57:57 AM »
MLC spent a bit of time at M4 last night. Looks like the CV on the rear axle is toast. Looking for an east side shop to do a rebuild (that's what I need, right Mike?). On the plus side, I have a nicer-than stock driveshaft that will now be good to go for spring Rausch trips.
« Reply #161 on: November 06, 2013, 09:21:43 AM »
Cook Brothers
156 Newbury St.Rochester,  N.Y. 14613Local: 1-585-458-1520
FleetPride Truck & Trailer Parts
Address: 1437 Scottsville Rd, Rochester, NY 14624
Phone:(800) 724-0849
Hours: Wednesday 7:30 am – 5:00 pm
Needs a full CV rebuild, should get a rear joint just because, and spin balance
« Reply #162 on: November 08, 2013, 01:09:00 PM »
Rear wheels are no longer connected to the engine.
Thanks to some tips from Mike I only injured myself 7 or so times. There's a reason I normally pay others to do this type of work.
Off to Scottsville.
« Reply #163 on: November 09, 2013, 04:44:34 PM »
Fixed. So is micro death wobble and steering wheel direction.
« Reply #164 on: November 12, 2013, 11:40:15 AM »
Need advice on tub "repair".
It is in pretty good shape. A few dents and surface rust. One area that concerns me is the rear passenger corner. There is rust "bubble" just forward of the roll cage. It isn't flaking, but is clearly deep in the metal. no rus is visible outside (wheel well). Do I just knock it off and bondo it or do i need to take more drastic measures.
It doesn't appear to go under the roll cage mount...
