Author Topic: TH/YJ stuff  (Read 1220 times)
TH/YJ stuff
« on: July 29, 2013, 11:35:57 AM »
TJ:
-Front grill, black minimal rust $250
-Rear bench seat tan, perfect cond. $100
-Dana 35 rear axle complete drum to drum with chipped 4.88 gears, have good 4.10's to go in $100 for everything
-Rear tow hook and hardware brand new: $20
-Rubicon Express track bar relocation bracket: $20
YJ:
Skyjacker Nitro Steering Stabilizer shock needs paint: $15
-Full set of front axle shafts with good u joints (two outer shafts, inner pass side shaft, and shift collar), $75 or can part out separately.
-Bestop tinted soft rear side windows.., used with very small fabric tear $30 for pair
-Aluminum radiator for 2.5L $50
-Fan shroud for 2.5L $30
-steering box. $50
-NP231J transfer case 21 spline (for 4 cyl). Has hairline fracture in case but can be patched. Good internals, needs tailshaft housing, $40
-2.5L computer and wiring harness. $50
-dual pump washer bottle (for hardtop sprayer). $20
-Set of gray sun visors $35 for the pair
-Drivers side black sun visor $15
-headlight switch $10, dimmer wheel $10, blank oem switch panel $10
-pass side inner door handle $5, black door hinge mounts (body side) $20
-interior full door panels, mint condition spice color $75 for the pair (these are $75 ea new)
-turn signal lenses for front grill. $10 for the pair
-front grill turn signal guards $10 for the pair
-fender turn signal lense $5
-set of four tires and wheels 235 75 15, 7" wide stock wheels. (tires are low tread but steel wheels and center caps are mint and have been sanded and painted gunmetal gray. $75 for everything
Many Hella 500 lights with covers and mounts $50 pair
4.10 gears for a Dana 35 $50
Call or text Matt 570-262-9664 prices are negotiable on most items (M4 discount)
