Author Topic: Crackers TJ  (Read 12496 times)
Crackers TJ
« on: July 24, 2013, 08:56:25 AM »
Since Big Dogs the battery has been dying in the Jeep.. jump it and drive it a bit and it would be good for a few days.. I figured something was draining it.. last night I jumped it and watched the volt gauge.. it was pegged at 19 for a bit...then dropped to 0 for a bit...then pegged at 19 for a bit... over and over.. Does that mean the Alt is dead?
Re: Crackers TJ
« Reply #1 on: July 24, 2013, 09:01:27 AM »
Most likely but battery may cause odd issues too.  Disconnect the batt with in running and watch.
Re: Crackers TJ
« Reply #2 on: July 24, 2013, 10:25:04 AM »
I'd try a fresh battery first, or at least a different one from something else.
Re: Crackers TJ
« Reply #3 on: July 24, 2013, 10:29:31 AM »
start, disconnect, measure alternator output.  should be 14.7ish
Re: Crackers TJ
« Reply #4 on: July 24, 2013, 10:43:31 AM »
ok stupid question.. do I just disconnect the + cable from the battery then put the meter between the + cable and the - terminal of the battery?
Re: Crackers TJ
« Reply #5 on: July 24, 2013, 11:23:27 AM »
ya
Re: Crackers TJ
« Reply #6 on: July 24, 2013, 11:23:47 AM »
dont lick anything
Re: Crackers TJ
« Reply #7 on: July 24, 2013, 11:36:57 AM »
Don't let the hot touch the chassis/ground
Re: Crackers TJ
« Reply #8 on: July 26, 2013, 08:01:41 PM »
Well jumped it then the meter read about 12.5 between the battery posts, but if i put the probes on the clamps it read 0.  Unhooked the positive and it was still 0.
So does that mean it is the alt?
Re: Crackers TJ
« Reply #9 on: July 26, 2013, 08:49:03 PM »
Rip alternator
Re: Crackers TJ
« Reply #10 on: July 26, 2013, 08:50:50 PM »
Wait wait wait, it reads 0 on the terminal still hooked to the battery?
Re: Crackers TJ
« Reply #11 on: July 26, 2013, 09:02:14 PM »
yes.. if the probes are directly on the posts it read 12+, move to the terminal clamps(still attached to battery) and it went to 0.
Re: Crackers TJ
« Reply #12 on: July 26, 2013, 09:14:08 PM »
clean your posts and clamps you should still have 12 at the clamps if your battery is full
Re: Crackers TJ
« Reply #13 on: July 26, 2013, 09:33:16 PM »
Posts and clamps should be the same if everything is hooked up. Clean 'er!!
Re: Crackers TJ
« Reply #14 on: July 27, 2013, 10:22:50 AM »
Yeah try it again.  I don't think posts could possibly be that corroded.
Regardless your alt is hosed.
