Author Topic: Kitchen Hauler 1.0  (Read 45248 times)
Re: Kitchen Hauler 1.0
« Reply #45 on: May 28, 2013, 04:27:43 PM »
« Reply #46 on: May 28, 2013, 04:33:30 PM »
see? easy.
« Reply #47 on: May 28, 2013, 09:04:26 PM »
I got trailer brakes working.  Tested on one tire that is majically in the air works, pins my battery charger.  Hooked up some broken wires under the floor and happy to see all upper marker lights functioning.  Just need to crawl under back gate to replace the cluster supplying power to tail lights.  Shouldn't be bad.
« Reply #48 on: May 30, 2013, 09:26:17 PM »
get rid of ALL wire nuts
they have no place in anything mobile.
« Reply #49 on: May 31, 2013, 10:27:59 AM »
or anything in weather. or anything with stranded wire, really... they're just terrible!
awl4928
« Reply #50 on: May 31, 2013, 10:39:13 AM »
Are they worse than the sweet hack and taps you don't like in my jeep?
« Reply #51 on: May 31, 2013, 11:10:27 AM »
They're about the same - but at least with a wire nut you have the wires cut there already and you're not putting a wound in a continuous wire run that you're going to have to trim back a foot on each side after it all turns green and stops working
« Reply #52 on: June 05, 2013, 01:26:37 AM »
Sitting back on new tires, thanks Jared!
« Reply #53 on: June 05, 2013, 09:00:43 AM »
also picked up (8) 11k tie downs last night at TSC
awl4928
« Reply #54 on: June 05, 2013, 10:23:46 AM »
Don't forget to get a replacement axle oil hub thingamabob.  I really just can't remember the word for it.
Kitchen Hauler 1.0
« Reply #55 on: June 05, 2013, 12:09:59 PM »
You don't wanna lose your axle oil!
« Reply #56 on: June 06, 2013, 04:39:31 PM »
thanks for reminding me! need to grab hub to take to regional- counter guy said he might have if its infront of him
awl4928
« Reply #57 on: June 06, 2013, 04:59:52 PM »
I can run to to the place up on Lyle for trailer stuff if they dont have it
Kitchen Hauler 1.0
« Reply #58 on: June 06, 2013, 05:25:33 PM »
Brad's has many useful things on the shelf. They'd almost certainly need a measurement or a sample though.
« Reply #59 on: June 06, 2013, 11:53:46 PM »
ya regional guy said brads too on lyell.
its a dexter 21-36  should be about 15$
