Author Topic: TurnedUp  (Read 126866 times)
Re: TurnedUp
« Reply #405 on: January 02, 2014, 12:43:33 PM »
leaky girl, will fit right in.
Re: TurnedUp
« Reply #406 on: January 02, 2014, 02:41:00 PM »
http://www.mightydiesel.com/store/product_info.php?cPath=108&products_id=1011
Thoughts? $5 more than normal head bolts. Planning to just go with a Felpro head gasket.
Re: TurnedUp
« Reply #407 on: January 02, 2014, 02:45:55 PM »
that product description is so sketchy hahaha
i'd run em.
Re: TurnedUp
« Reply #408 on: January 02, 2014, 02:47:11 PM »
i like how they explain 90 degrees
Re: TurnedUp
« Reply #409 on: January 02, 2014, 02:52:34 PM »
incase the bolt stretches here a few extra lol
Re: TurnedUp
« Reply #410 on: January 04, 2014, 07:51:35 AM »
The 90* is straight from cummins! Crazy, yessir.
Re: TurnedUp
« Reply #411 on: January 05, 2014, 11:34:25 PM »
Re: TurnedUp
« Reply #412 on: January 06, 2014, 09:32:07 AM »
bitch to get past the cowl and core support at the same time, eh?
Re: TurnedUp
« Reply #413 on: January 06, 2014, 09:39:00 AM »
Bring back memories, Mike?
Re: TurnedUp
« Reply #414 on: January 06, 2014, 09:53:09 AM »
I think the biggest pain was disconnecting the motor mounts from the block to free up some wiggle room. Not much room to get in there on either side.
Re: TurnedUp
« Reply #415 on: January 06, 2014, 10:03:34 AM »
changing a cummins cam shaft in a 24' garage is way more fun, come on.
Re: TurnedUp
« Reply #416 on: January 06, 2014, 10:08:26 AM »
camshaft was child's play level easy compared to R&R the complete motor! It's like changing a transmission in 571, except heavier.
Re: TurnedUp
« Reply #417 on: January 06, 2014, 10:40:27 AM »
I am at a fork in the road.
I have an opportunity to buy the following for $1500:
97 4x4 auto single cab
291k
Pretty rusty
P-pump, vac/steering pump, timing cover swapped onto a 1st gen
Good mud tires on stock wheels
Driveshafts and t-case gone
Motor supposedly rebuilt, original owner who would know when and other details has passed. Motor has zero oil on it, so seems plausible.
Comes with a 180hp p-pump that the #6 barrel sticks when hot.
I got an offer for my motor for $800 complete.
I plan to put $300 worth of gaskets and head bolts on any motor before it goes in.
Yard motor that I can give someone hell if it doesn't run good? Or risk the unknown but good looking motor and potentially be into the whol ordeal for <$500 after scrap/partout.
Bahhh!!!
Re: TurnedUp
« Reply #418 on: January 06, 2014, 10:43:37 AM »
97 auto will not be a 215 pump remember. I would go with the truck you can drive plus scrap and other parts you can get out of it
Re: TurnedUp
« Reply #419 on: January 06, 2014, 10:45:56 AM »
It's only money (and time)... ;D
