Author Topic: new 5.9 whip  (Read 30805 times)
Re: new 5.9 whip
« Reply #90 on: January 01, 2013, 10:24:50 PM »
doubt it,
its gota have a 190 or 210 stat in it
my xj goes right to 190 in 2 minutes
new 5.9 whip
« Reply #91 on: January 02, 2013, 12:02:28 AM »
sounds like a bad heater core ,cherokees dont run much hotter than *120
Cherokees with stuck open tstats, perhaps.
Re: new 5.9 whip
« Reply #92 on: January 10, 2013, 09:29:07 AM »
this guy has 2 codes
No CEL indacated, but chip and I were messing with our bluetooth readers last night
soemthing about trans lock upcircuit
and another code that made sense, not sure
Re: new 5.9 whip
« Reply #93 on: January 29, 2013, 09:32:18 PM »
Buy them wheels
http://rochester.craigslist.org/pts/3541736125.html
Or buy the whole truck for scrap price
Re: new 5.9 whip
« Reply #94 on: February 02, 2013, 06:42:33 PM »
chad knows the sellar- guy bought it at auction by acident for 600$
to busy to get out there
Re: new 5.9 whip
« Reply #95 on: February 02, 2013, 06:43:33 PM »
changed a wheel bearing on this guy today
found a rotted hose with a hole in it on the EVAP canister-  2 hrs to get to it and back through the head light
hope that makes it pass NYS next time
Re: new 5.9 whip
« Reply #96 on: February 18, 2013, 02:20:59 PM »
wont pass emisions, keeps saying not enough data and monitors wont set.
I think its because it technically doesnt get to engine operating temp.
Still hates to find its idle upon hot restart also.
stuffed cardboard infront of the radiator last night when i left buffalo, at least i got some cabin heat, but she doesnt like the warm up with 11 degree ambient!
Re: new 5.9 whip
« Reply #97 on: February 18, 2013, 02:24:22 PM »
have you flushed the system yet?
garden hose to the opposide side of the heater core...  shit will run old BLACK...
Re: new 5.9 whip
« Reply #98 on: February 18, 2013, 02:26:42 PM »
its from California, clean shinny green fluid, im guessing someone pulled the TSTAT, or its stuck open.
it sits at 100degrees after an hour of thruway driving
Re: new 5.9 whip
« Reply #99 on: February 26, 2013, 10:23:16 PM »
just as i suspected- no stat present.
new stat
TPS
iacv
new 5.9 whip
« Reply #100 on: April 01, 2013, 05:01:00 PM »
Poor niner
new 5.9 whip
« Reply #101 on: April 08, 2013, 10:06:39 PM »
Do you want my 242 for this hog? Straight bolt in. Internal slip yoke so only one you're gonna find that wont require rear driveshaft mod
$100
new 5.9 whip
« Reply #102 on: April 08, 2013, 10:50:31 PM »
That awd/4hi/4lo right?
Re: new 5.9 whip
« Reply #103 on: April 09, 2013, 07:10:12 AM »
242 is 2wd/4pt/4at/4lo
Re: new 5.9 whip
« Reply #104 on: April 09, 2013, 09:19:06 AM »
any issues with it? does it pop out at all when wheeling?
ill probably take it if it will bolt up same splines and such.  i have the trim bezel aready.
