Author Topic: new 5.9 whip  (Read 30831 times)
Re: new 5.9 whip
« Reply #30 on: November 29, 2012, 12:03:18 PM »
 8)
it will get a once over when the lift is back in the shop-  has some front end noise, i think the front shaft is making it.
heated seats were nice this morning
Re: new 5.9 whip
« Reply #31 on: November 29, 2012, 12:20:04 PM »
surprised they have enough time to heat up ;D
Re: new 5.9 whip
« Reply #32 on: November 29, 2012, 12:21:06 PM »
5 starts on the brought back to life battery
new 5.9 whip
« Reply #33 on: November 29, 2012, 03:49:42 PM »
Need a remote start on that hog so she can get up to temp once in a while
Re: new 5.9 whip
« Reply #34 on: November 29, 2012, 04:13:55 PM »
they overheat
Callelle
Re: new 5.9 whip
« Reply #35 on: November 29, 2012, 04:32:39 PM »
they overheat
That could be considered up to temp >.>
Re: new 5.9 whip
« Reply #36 on: November 29, 2012, 04:50:38 PM »
those little bastards cook my ass on high
Re: new 5.9 whip
« Reply #37 on: November 29, 2012, 09:59:20 PM »
Concern: How To Program a New Remote
Cause: -
Resolution: Up to 4 remotes can be programmed into receiver at any given time. 1) Locate the receiver...look for a black half-sphere on the rear portion of the overhead console. 2) Sit in driver seat and close door. All doors should be closed. 3) Open driver's door. Leave it open through the programming procedure. 4) Slide mechanical door lock lever to the LOCK position. DO NOT use the switch. 5) Insert ignition key and turn it to RUN position. DO NOT start the engine. Within 20 seconds, aim a remote at receiver dome and press and hold lock button until the power locks cycle. (When receiver accepts programming code the driver's door will unlock.) 6) Once the first remote has been programmed, additional remotes (up to 4) may be programmed into receiver. Within 20 seconds of the previous remote programming, move the mechanical door lock lever to LOCK position. Aim another remote at receiver dome and press LOCK button for at least 5 seconds. The door lock will cycle again. 7) To lock the programmed codes into the receiver, the ignition must be turned off and back on within 20 seconds after programming the last remote's code. At that time, all previous codes are erased from the module.
Re: new 5.9 whip
« Reply #38 on: November 29, 2012, 10:03:25 PM »
crap
96-98 has to be programmed by the dealer. Totally different system.
Re: new 5.9 whip
« Reply #39 on: December 01, 2012, 09:10:43 PM »
Re: new 5.9 whip
« Reply #40 on: December 01, 2012, 10:14:25 PM »
replaced gage cluster (was missing clear inset)
replaced the information center display
Re: new 5.9 whip
« Reply #41 on: December 05, 2012, 12:53:20 PM »
looking at AZ prices, its actually pretty cheap to just put CV axles back in the front....
this thing will never be wheeled, and i really feel like swaping a 231 in...  trying to decided if i should just put new CVs in and call it good when that fits the vibs
Re: new 5.9 whip
« Reply #42 on: December 05, 2012, 12:55:17 PM »
i have CV's for that thing...
Re: new 5.9 whip
« Reply #43 on: December 05, 2012, 12:58:42 PM »
i really dont feel like swaping a 231 in*
the CVs are probably 40$ a side your cost, i figured thed be like 100 something
ill wait till i can actually get it on the lift and trouble shoot the vib,
Re: new 5.9 whip
« Reply #44 on: December 05, 2012, 01:16:55 PM »
leave the 249 till the VC goes...
and for that it might never go...
driving a ZJ with AWD is night and day different than 2wd... I dont think youll like it
