Author Topic: CL finds  (Read 455708 times)
Re: CL finds
« Reply #2580 on: November 01, 2017, 09:48:19 PM »
Old iron donor?
Re: CL finds
« Reply #2581 on: November 02, 2017, 11:50:44 AM »
absolutely if it's a runner.
Re: CL finds
« Reply #2582 on: November 02, 2017, 11:54:45 AM »
That old D350 will make a great power plant donor to swap in a smaller engine bay as its non-intercooled
Re: CL finds
« Reply #2583 on: November 02, 2017, 01:44:35 PM »
dude hasent responded to a single post or question on that FB listing.....
boat anchor
Re: CL finds
« Reply #2584 on: November 06, 2017, 11:39:08 AM »
35k btu wate oil burner 180$
https://buffalo.craigslist.org/for/d/oil-heater-coleman-model-871/6349640019.html
i have two full drums of clean oil needing pick up!
Re: CL finds
« Reply #2585 on: November 06, 2017, 11:46:14 AM »
that's tempting. if I had the floor space I'd probably go get it and replace my garage window with a stack. if it runs on that tank for 20hr I bet I could self sustain with my own waste oil since I seem to make about 30 gallons per year. top draw on a well settled drum would probably be just fine.
Re: CL finds
« Reply #2586 on: November 06, 2017, 12:53:52 PM »
There's no way, my home built went through about a gallon an hour
Re: CL finds
« Reply #2587 on: November 06, 2017, 01:39:49 PM »
troy im going to guess this Coleman unit is a little cleaner in operation than your unit.  also, not it says when turned down, 20hrs.  at full 35000btu load its probably much higher.
Re: CL finds
« Reply #2588 on: November 06, 2017, 03:36:41 PM »
if that thing get 20+ hours at 35k btu's on that what looks to be a 4 gallon tank, ill eat dogshit
Re: CL finds
« Reply #2589 on: November 06, 2017, 04:23:03 PM »
troy im going to guess this Coleman unit is a little cleaner in operation than your unit.  also, note* it says when turned down, 20hrs.  at full 35000btu load its probably much higher.
note*
Re: CL finds
« Reply #2590 on: November 06, 2017, 04:49:52 PM »
you are quoting it wrong," Will run continuously at full rated output for 20 hours, more if you dial it back." i mispoke when i say 20 hours plus, but he says will run longer if dialed back. a kerosene unit which is 99% efficient will burn 2 gallons at 20k-23k  btu's for 8 hours
Re: CL finds
« Reply #2591 on: November 06, 2017, 05:04:28 PM »
ah, ya he does claim 20 hrs at full.
you still sound butt hurt
Re: CL finds
« Reply #2593 on: November 09, 2017, 05:08:38 PM »
Re: CL finds
« Reply #2594 on: November 10, 2017, 03:02:07 PM »
 That's a good size vise
Sent from my SM-G955U using Tapatalk
