Author Topic: Fix the wedge  (Read 45985 times)
Re: Fix the wedge
« Reply #120 on: June 06, 2013, 12:35:47 PM »
mmkay
Re: Fix the wedge
« Reply #121 on: June 06, 2013, 12:36:29 PM »
just put it up for 2500 as is lol
Re: Fix the wedge
« Reply #122 on: June 06, 2013, 12:39:25 PM »
it needs work. sounds likely it'll be going to VA soon.
Re: Fix the wedge
« Reply #123 on: June 06, 2013, 02:38:57 PM »
im still waiting to seee what the person wants to do....
Re: Fix the wedge
« Reply #124 on: July 21, 2013, 05:28:47 PM »
Has been moved to NuWay south.
Re: Fix the wedge
« Reply #125 on: July 21, 2013, 05:32:22 PM »
10-4
This what the call I missed was regarding?
Re: Fix the wedge
« Reply #126 on: July 21, 2013, 07:20:14 PM »
No. Trailer question no worries
Re: Fix the wedge
« Reply #127 on: July 21, 2013, 08:04:53 PM »
With no vm and no text I assumed it was critical :)
Re: Fix the wedge
« Reply #128 on: February 26, 2014, 09:40:09 AM »
this available for a srw cummins retrieval from Wellsville NY? tire status?
asking price still as discussed?
Re: Fix the wedge
« Reply #129 on: February 26, 2014, 10:14:21 AM »
I don't remember discussed price. almost certainly though ;)
I believe it has the ATs on it now with spacers and inadequate lug nut engagement. Tires could be swapped for what is on the Dakota right now - it has 3 new and one old proper size proper backspace. Those could be included for the right price.
It is available and so is lowboy which may be better all around as long as you have a legit brake controller for the sweet hydraulic brakes. pickup and especially return parking is much easier w the wedge.
Re: Fix the wedge
« Reply #130 on: February 26, 2014, 10:30:17 AM »
I have a P3 which will run hydraulic, correct?
I would love to try out real brakes and see how much I will be forced to spend once I fall in love with them.
Truck that is being picked up is inop. Both trailers have functioning winches, correct? do either need special hookups for them?
Re: Fix the wedge
« Reply #131 on: February 26, 2014, 10:33:38 AM »
wedge wired remote was lost, has no onboard battery. I have wireless remotes that could be installed.
I lost the lowboy wireless remote and need to swap out that brain. wired works fine. has onboard battery.
I run a P3; I want to swap out to their controller to see if it helps build pressure faster initially since it has feedback.
Re: Fix the wedge
« Reply #132 on: February 26, 2014, 11:04:32 AM »
I believe matt has an extra full set of trailer tires that were in ok shape off his enclosed.  F rated tires and wheels got swapped on.
The winch on my wedge only works with the international
Re: Fix the wedge
« Reply #133 on: February 27, 2014, 12:26:01 PM »
If lowboy is available Sunday that would be awesome. What is appropriate compensation for a day of use? Pick up late morning, drop off in the evening. I can mess with the remote if you have the correct brain for it.
Will the wiring reach my 7 pin on the bumper?
Re: Fix the wedge
« Reply #134 on: February 27, 2014, 12:36:49 PM »
real trucks have plugs where they belong.
I have an extension for fake trucks ;)
Can you swing by this evening for a tour of needed configs? I have dog class, will be home right after work. 6ish? Might be able to swing earlier.
