Author Topic: 258 oil pan  (Read 4212 times)
Re: 258 oil pan
« Reply #15 on: June 07, 2012, 11:54:07 AM »
you need a 1 pc. rubber gasket, change the RMS while your in there...
and while the pan is off.... might as well take a good hard look at it..
carchameleon
Re: 258 oil pan
« Reply #16 on: June 07, 2012, 12:25:39 PM »
that was part of my plan
how much are the gaskets?
how much for one of your pans?
Re: 258 oil pan
« Reply #17 on: June 07, 2012, 12:28:55 PM »
if you help Mike load a bike at some point today you can have the pan....
I have a feeling its a 2 man job, easier if one of those men knows how to opperate a motorcycle..
Re: 258 oil pan
« Reply #18 on: June 07, 2012, 01:01:31 PM »
i would not F with the rear main on the motor, it has like 6K miles on it
i guess ill stop with my  $0.02   :-X
258 oil pan
« Reply #19 on: June 07, 2012, 01:21:29 PM »
Agreed on mains unless they're surely leaking.
carchameleon
Re: 258 oil pan
« Reply #20 on: June 07, 2012, 01:32:20 PM »
ok, talking to mike now
carchameleon
Re: 258 oil pan
« Reply #21 on: June 08, 2012, 07:47:13 AM »
i'm going to say the oil pan will fix it, when i take it off i'll look at it closer
arie, when are you around so i could pick the pan up
how much is a gasket from you?
ok if i grab your welder at the same time?
thanks
Re: 258 oil pan
« Reply #22 on: June 08, 2012, 08:23:27 AM »
saturday noon at carter would be the one stop shop
carchameleon
Re: 258 oil pan
« Reply #23 on: June 08, 2012, 08:46:38 AM »
ok, sounds good
thanks
