Author Topic: 2006 Magnum  (Read 29628 times)
2006 Magnum
« on: June 01, 2025, 11:27:35 PM »
Dads car. Now Sarah’s present daily.
Just got new front rotors, calipers, pads
Rear rotors turned and new pads.
Tires rotated
100,433
Insides of all four rotors were trashed. Brakes are massively better than even the day we brought it home in probably October or November.
Needs a RF tie rod outer boot, I didn’t have one deep enough in stock for IFS
Might need a left rear caliper. I think the only thing that could ruin rotors like that is dragging brakes, and that one is by far the warmest after a test drive. I’ll give it a day. Only the left front looked bad, one piston had a bad seal and inner pad was worn crooked.
Brake lathe worked pretty well. Learn more every time I use it. I never did make parts to make it work on the dually
With the Ram down, it had to play truck on Saturday for trash and an oil pickup from a repeat supplier. Adding a thousand pounds told me how bad the brakes really were. They’d gotten a lot worse since December Montréal trip, last time I put many miles on it. Brakes were quite urgent.
Better (slightly) car picture since its first thread post
Re: 2006 Magnum
« Reply #1 on: June 02, 2025, 02:47:13 PM »
love the brake lathe use.
sorry i didnt have time (and still dont) to grab the oil.  i guess i should have offered one of my 4 trucks sitting here to you if i knew you were renting a trailer because of it  :o
Re: 2006 Magnum
« Reply #2 on: June 02, 2025, 03:32:31 PM »
Costs me more in time to run to Victor to grab it than it does in dollars. Those are $16/day incl tax.
This one happened to cost about $80 though - forgot to mention that the trailer wiring module was shot. Didn't pass anything, and also turns out it was wired backwards for the turn signals from whoever Dad had install it... Had to replace it from UHaul retail priced stock due to timing, but got that done in about 15m in the parking lot to get the trailer before closing.
I wouldn't hesitate to grab a small cargo trailer with ramp from them any time. With those rates it's hard to justify buying one.
No worries - hope the time crunch isn't for any bad reasons.
I've been a bit of a mooch lately among us with constant issues and limited time myself.
Re: 2006 Magnum
« Reply #3 on: June 02, 2025, 08:09:38 PM »
16$ good to know lol
nope just jeeps for days.
Re: 2006 Magnum
« Reply #4 on: June 02, 2025, 11:19:40 PM »
Worst of the used pads slapped on the sticky corner. Cool after a test drive with new clean piston exposed.
Rockauto calipers 40% the cost of Advance, and no silly split order discount BS to deal with. Just shipping of cores.
Will be in Thursday and no longer an issue today.
2006 Magnum
« Reply #5 on: June 18, 2025, 06:39:36 PM »
Sarah decided to cut two sidewalls leaving work avoiding flooded road today. Replacing 85% tires bought new hurts. Fuck.
Avoided a tow home, Mr. Tire on W Henrietta gets very high marks from me.
« Last Edit: October 08, 2025, 08:26:33 PM by mr.mindless »
Re: 2006 Magnum
« Reply #6 on: June 18, 2025, 06:41:58 PM »
Re: 2006 Magnum
« Reply #7 on: August 01, 2025, 05:19:01 PM »
failed inspection for loose right inner tie rod end.
ordered all 4. the right outer needs a boot and I failed at matching it up from stock.
can't wait to see how loose it really is. it wasn't when I had it in the air a month ago. that'll extra piss me off.
Re: 2006 Magnum
« Reply #8 on: October 08, 2025, 08:26:10 PM »
Whelp right rear caliper fell out of this today. So that’s cool. Didn’t break the wheel, so could be worse.
Will probably need a knuckle. I may have written something above about threads feeling like they were weak when I changed the calipers 6 months ago. I know dad had a fight of some flavor with them too, but I thought the knuckle got changed.
Re: 2006 Magnum
« Reply #9 on: October 12, 2025, 11:46:49 PM »
helicoil and loaded caliper with braket ordered. bosses on the knuckle look structurally fine but the upper bolt lost its threads and sent the caliper into the wheel. did dent the inside of the wheel, need to make sure it's not losing pressure and isn't cracked.
Re: 2006 Magnum
« Reply #10 on: October 17, 2025, 01:07:21 AM »
One of the helicoils fought me a skosh but this is all buttoned up. Needs final bleed and the tire thrown on, and an oil change.
The tie rod that failed its inspection is a barely detectable click. Poor tire balance has a slight shake at 60-68 (more poor luck with balancing beads on small/light tires!) and they blamed the tie rod.
Not sure if I’m feeling the ambition to try out my alignment hardware for the first time for real.
Re: 2006 Magnum
« Reply #11 on: October 21, 2025, 10:31:27 PM »
Oil and filtering at 105,562
Found left front inner cv boot torn. Axle ordered.
That tie rod has the TINIEST click. Bullshit fail. Didn’t change. Will do along with axle.
Re: 2006 Magnum
« Reply #12 on: October 22, 2025, 10:18:44 AM »
Never realized Magnums had AWD as an option.
Re: 2006 Magnum
« Reply #13 on: November 25, 2025, 08:16:26 PM »
Inner and outer tie rods swapped. Forced the cradle as far to driver as it would go and got camber barely in spec. Adjusted toe on right rear as well
Alignment machine is stupidly picky on alignment heads. Likes to lose their happy place. After getting camber happy I lost the right front and don’t know what that did to toe. Rack is on the subframe too so it’s probably fine. Couldn’t keep them happy enough to put numbers on caster. And now I don’t have final toe. Very frustrating day with that after also clipping four burned caps and replacing two blown fuses. But I guess I kinda have an alignment machine.
I wish the newer one hadn’t shat the bed.
Also love that this is another car that can’t sit in neutral without killing the battery. Fuck every shifter with that interlock.
Milage some 106500ish number.
Re: 2006 Magnum
« Reply #14 on: November 25, 2025, 11:37:48 PM »
Didn’t nail a straight steering wheel. Nearly as frustrating as the traction control and abs lights and check engine light it picked up.
I swear I used to be an ok - if slow - mechanic. Skills atrophied? Dad haunting the car? Just way out of practice?
Left my usual easy code reader in mom’s car up there so couldn’t plug in to see what the abs deal is. Either way doesn’t matter, fucked for inspection tomorrow.
Hope the axle doesn’t have the wrong tone ring on it. Wrapped in plastic, so I can’t see the tooth pitch. Abs sensor very well protected in the hub, shouldn’t have been able to hurt it. Fml
