Author Topic: TDI Wonder 4.0  (Read 79493 times)
Re: TDI Wonder 4.0
« Reply #75 on: January 13, 2024, 09:38:47 PM »
fuel leak was a return line plug having gotten spit out. concequence of adding a couple psi of positive fuel pressure. I wonder if any others will pop off now that a new plug is clamped in.
Reconnecting the battery with the key on disabled the alarm. remote refuses to work. Forgot my diagnostic laptop up in Rochester so going to probably ignore the rest of this until later so I can properly diag all the switches in the doors too, but at least it's drivable again..
Re: TDI Wonder 4.0
« Reply #76 on: January 21, 2024, 02:25:31 PM »
Looks like the fuel leak ate a cooling system o ring? Or coincident failure. Looks like o ring 13 or pipe 11 is dribbling coolant. Hard to see for sure behind the injection pump, but I don’t think it’s parts 9 or 13 that got changed a few months ago.
Re: TDI Wonder 4.0
« Reply #77 on: September 15, 2024, 07:44:04 PM »
This guy seems solid. Driver door lock doesn’t reliably unlock with handle pull so door won’t open. Would be a good thing to fix.
Solid bite on this from on of the kids that bought the Malibu. They test drove it today.
