Author Topic: "Race" Tractor  (Read 14438 times)
Re: "Race" Tractor
« Reply #30 on: April 24, 2022, 03:54:14 PM »
Picked up 2 junk quads for IFS parts and a third tractor. Has a 16hp Kohler single.
Missed a missing PTO on it, and I wired it enough to start it and it sounds like it needs a rebuild. Disappointing.
Re: "Race" Tractor
« Reply #31 on: April 24, 2022, 06:35:44 PM »
Adjusting timing helped (set points) but it’s not perfect… shoved to back of shop for now. May just be parts.
Re: "Race" Tractor
« Reply #32 on: April 27, 2022, 10:17:58 AM »
Re: "Race" Tractor
« Reply #33 on: April 27, 2022, 12:04:28 PM »
if that is that, how'd he lose his race at the 1minute mark?? what's in the OTHER tractor?
« Last Edit: April 27, 2022, 01:08:15 PM by mr.mindless »
Re: "Race" Tractor
« Reply #34 on: April 27, 2022, 01:07:51 PM »
all parts to put the 16hp Kohler together right are in. fuel pump, head gasket, starter solenoid. I _think_ some of the gaskets in that head gasket kit will help me fix a leak in the 12hp Kohler on the already-built tractor too.
Got a how-to on adjusting the bypass in the travel control valve so that I should put more power to the ground, too.
I haven't quite figured out how I want to do foot travel control yet but it sure does have me thinking about a small plasma table instead of continuing to hand-cut parts.
Re: "Race" Tractor
« Reply #35 on: April 27, 2022, 04:02:52 PM »
you've went too far
Re: "Race" Tractor
« Reply #36 on: May 01, 2022, 08:55:03 PM »
You’re probably correct.
The k341 16hp single does have some pretty loose bearings. I was able to feel crank to rod through the fuel pump hole.
If hard parts are less than a couple hundred I might consider a rebuild but meh. I’ll leave that one for later.
Re: "Race" Tractor
« Reply #37 on: June 24, 2022, 07:28:39 PM »
Callelle
Re: "Race" Tractor
« Reply #39 on: June 26, 2022, 07:57:23 PM »
That’s a sweet ride!
Re: "Race" Tractor
« Reply #40 on: August 28, 2022, 11:43:00 PM »
Here is uour next KOT tractor... Honda.  11 hp, 4 wheel drive, 4 wheel steer https://www.facebook.com/marketplace/item/517761306817468/?ref=facebook_story_share
Re: "Race" Tractor
« Reply #41 on: August 29, 2022, 08:42:01 AM »
Thats a sweet machine
Re: "Race" Tractor
« Reply #42 on: August 29, 2022, 11:42:38 AM »
Wow, that is neat!  Great shape too.
Re: "Race" Tractor
« Reply #43 on: August 29, 2022, 12:11:14 PM »
that's pretty wild!
