Author Topic: 1950 Chevy 6400  (Read 54817 times)
Re: 1950 Chevy 6400
« Reply #60 on: April 17, 2021, 02:18:52 PM »
2008 6.0 with an oil pressure problem? $3k 4x4 10’ cab n chassis. Frame scaly.
Similar fears to the can’t hear it run duramax. How long run with low oil pressure and how bad hurt. It’s almost like signing up to roll new bearings in at least while changing the oil pump.
https://www.facebook.com/marketplace/item/2861113130823185/
Re: 1950 Chevy 6400
« Reply #61 on: April 17, 2021, 02:33:17 PM »
i bet you would get a year out of it with 20-50 and lucas in it.
id still probably pass on it though.
cats might be big spendy ones though
Re: 1950 Chevy 6400
« Reply #62 on: April 18, 2021, 08:29:17 PM »
So what model would be 16k gvwr in a Chevy? The emblems don’t have a model, just “Chevrolet”. The serial number tag is a little rough, hopefully not too difficult to get a good rubbing from.
Steers on it are 7.5-20, 35-36”. Drives are 8.25-20, 37-38”. Will be hard to get modem running gear narrow enough for my taste but I will try. And may sacrifice turning radius for it. Maybe.
First donor truck I looked at in Marion right after picking up the truck was kinda crap. Lots of frame scale and one rotten crossmember. Also 4x2, accidentally. Would be easy to put a coil spring axle under there the way the coils pockets are in the frame. Didn’t check width for spacing of those spring pockets though.
Need to pull some other dimensions off things for frame height and spacing. I love the proportions and want to stay close.
Re: 1950 Chevy 6400
« Reply #63 on: April 18, 2021, 08:44:35 PM »
6000 series, past that depends on wheelbase and cab options.
Re: 1950 Chevy 6400
« Reply #64 on: April 18, 2021, 09:07:33 PM »
180” wb
Re: 1950 Chevy 6400
« Reply #65 on: April 18, 2021, 09:14:56 PM »
lots of things on google with the vin
Re: 1950 Chevy 6400
« Reply #66 on: April 18, 2021, 11:08:48 PM »
November 1950 build. Either a 6100 or 6500. Depends if it’s a V or a Y and they damn near stamped through the plate on that character. Tough to tell.
Idk if that makes it a 50 or 51. Sold as 51. Papers were not located.
Re: 1950 Chevy 6400
« Reply #67 on: April 19, 2021, 08:27:03 AM »
Wikipedia design notes tell me the cab is a 1950. I have the driver side cowl vent with flat steel actuator. Load emblem-less hood indicates 1953. I think I’m understanding that tappet cover design on engine indicates 1955(?)+ 261 cid i6, not the 216 that would have been stock until 54 (at least in the light duty trucks.
Re: 1950 Chevy 6400
« Reply #68 on: April 23, 2021, 09:59:58 AM »
Accidentally deleted this post, guess I'll have to start from scratch. there's no way to recover a thread.
1950 chevy 16k gvw. 180" wheelbase and 180" bed. steers, rows gears, rolls and holds air. new glass and seals. trim nearly if not completely complete. needs driver floor work, needs door hinge work, needs window felts and door seals and a driver cab-side latch strike. haven't looked at wipers. has newer heater present but no ducts. brake linkage siezed.
motor free. after some work has compression in 1-2-3- -5- . Suspect burned exhaust valves in 4 & 6. some mildly bent pushrods. Pushrod dimensions indicate motor likely a '54 car 235, but not definitive yet. I may continue to poke at that and see if it'll run. Should just list it for sale and send it. Engine work is only impeded by having a cab present, anyway. probably time to separate.
no spark yet either. Have new coil to try. has been swapped to 12v.
cab-side wiring needs to just be gutted, it's scary. so no function check on lights or fans or anything. original gauges present but very cloudy.
currently leaks from center of windshield. that leak rotted the bottom of the dash.
cab corners are bondo but look good. center trim strip on hood has rot. beauty line on cab shows rust. I'll see what gets uncovered when I take care of cab mount and driver side floor, if I can leave the cab mostly as-is for now that's my plan. if big chunks of body filler fall out of it I'll go from there. door bottoms have perforation but doesn't show from outside and isn't at all structural. it feels VERY solid.
picked up donor truck last night, it's rough but I think it's close to good.
2000 ram CCLB 24v auto 4x4
need to shift trans manually due to year mismatch. if in D, will start in 2 instead of 1.
3.55 open/open. needs front-front driveshaft ujoint, rear pinion bearings, right rear wheel seal
scary steering. box broke 2 bolts years ago and pulled the one remaining bolt through frame. strong chances that needs a better repair. probably trash track bar too. maybe also bad drag link or box. it's 2/3 turn of slop.
plow blade needs to be rebuilt. plow frame is fantastic.
truck frame has confirmed rot at the front spring hanger frame section seam. I'm sure I'll find other bad spots. hitch appears good.
water pump bad
fresh alternator
fuel leak at return line from vp44
cable-actuated CAD
$3 in bottle returns in the bed, along with a chrome stack that previous owner was running, and 16" alloys.
power steering very weak - intermittently. hydroboost brakes. that may mean no vacuum pump?
hack-fix lift pump; EFI fuel pump on the frame rail on separate switch; draw straw in the tank. out of fuel at last hash before E on gauge.
Edge programmer. when on highway duty, used to do 24-26mpg calculated.
since I'm going to want 37s or so, I wonder if I'll be wanting a gear swap.
Re: 1950 Chevy 6400
« Reply #69 on: April 23, 2021, 10:24:57 AM »
o snap did i just beat the IT guy!>
Re: 1950 Chevy 6400
« Reply #70 on: April 23, 2021, 11:23:00 AM »
smike hacked the main frame
Re: 1950 Chevy 6400
« Reply #71 on: April 23, 2021, 11:23:55 AM »
What size are those tires on the Ram? They look larger than stock.
Re: 1950 Chevy 6400
« Reply #72 on: April 23, 2021, 11:44:23 AM »
Zeetex AT1000 285/70r17
Re: 1950 Chevy 6400
« Reply #73 on: April 23, 2021, 11:58:40 AM »
You sure did! I owe the winner a chicken dinner!
Re: 1950 Chevy 6400
« Reply #74 on: April 23, 2021, 12:34:25 PM »
if you are not set on the Dodge.. $1500 2000 Ford F-250 Super Duty Long Bed
https://www.facebook.com/marketplace/item/1181168769008138/
