Author Topic: Plowpile for mikemike  (Read 60469 times)
Re: Plowpile for mikemike
« Reply #30 on: February 20, 2021, 06:31:35 PM »
Need to cut the fan shroud. Noisy. Some body mount moved.
20 min quick plow. Not sure if I could avoid spoil piles if I took 30 but they don’t much matter. It’s 30 for a more thorough job but it snowed 2 more inches while I was plowing so F it.
Wishing for a sled and loving this weather.
« Reply #31 on: February 20, 2021, 06:48:18 PM »
ZJ got stuck today me being dumb trying not to push snow at the RAM and avoid falling off the RTI wall
tractor 3 point was nice to just chain to the hitch and lift, drive away with it in N  haha
Also nice to have a Tractor that cold starts 100% fine
moving snow with tractor is painfully slow though, did that last week to clear lower door.  meh
« Reply #32 on: February 20, 2021, 07:06:53 PM »
Snowplow is MUCH faster! Tractor only useful to stack snow or push back piles.
« Reply #33 on: February 20, 2021, 08:07:15 PM »
I hung a plow blade on the front of my tractor off the bucket.  Its nice to be able to adjust height and tilt and angle.   Also to be able to push snow up into big piles.
« Reply #34 on: December 17, 2021, 03:32:09 PM »
All issues were low volts. Probably in combination with terrible wiring, high resistance grounds, and god knows what other fire risks…
“ready”.
« Reply #35 on: December 17, 2021, 04:00:34 PM »
sure.. you guaranteed it definitely WON'T SNOW now!!!  not that I am totally complaining.
« Reply #36 on: December 18, 2021, 08:21:21 AM »
What a machine!
« Reply #37 on: January 13, 2022, 01:47:04 PM »
moved this into the shop in case there was any snow from this most recent storm. plow pump runs but it will only move down. not left right nor up.
beginning to see why people put plows on daily driven new trucks lol
« Reply #38 on: January 13, 2022, 03:11:19 PM »
is it like the myers all in one thing like the shovel had?   i replaced the gears on the pump once. also the cables like to break/freeze
« Reply #39 on: January 13, 2022, 03:31:32 PM »
This
« Reply #40 on: January 13, 2022, 07:49:48 PM »
I suspect it’s the wiring between the controller and solenoids. I’d suspect solenoid power supply except it does drop. Thankfully I had parked it in the air.  Hopefully take a look at it tonight
« Reply #41 on: January 13, 2022, 10:54:45 PM »
Fine after sitting in the warm shop. ¯\_(?)_/¯
« Reply #42 on: January 13, 2022, 11:21:44 PM »
don't worry.. it will be warm when you need to use it!!
« Reply #43 on: January 14, 2022, 08:51:34 AM »
Good work!
« Reply #44 on: January 14, 2022, 12:21:21 PM »
mid jan now, and still havent needed to hook my plow.  hoping to just skip entirely this season.
