Author Topic: axle set up specs  (Read 30441 times)
Re: axle set up specs
« Reply #1 on: May 04, 2020, 01:03:51 PM »
« Reply #2 on: May 04, 2020, 03:06:13 PM »
I get my axle set up specs or info from here. FWIW.
https://media.spicerparts.com/
« Reply #3 on: May 06, 2020, 07:30:23 AM »
search AAM 11.5   : no matches.   lots of PDFs and i got bored trying to look for minutes for something.  Not useful in this case to me.
« Reply #4 on: July 20, 2023, 09:47:16 AM »
brushing up on some miata specs for a third member coming.
very neat, there is a diagonal bearing cap preload measurement?  lol WTF
scroll down to bottom of page of link if your bored
https://www.miata.net/garage/diff_rr.html
Differential Specs:
1.6 Specs
Ring Gear 51-61 ft-lbs
Backlash 0.0035-0.0043 inches
Distance between bearing caps(bearing preload) 5.9105-5.913 inches
Bearing cap torque 27-38 ft-lbs
lock plate bolt torque 13-19 ft-lbs
1.8 Specs
Ring gear backlash (0.0036-0.0043)
Bearing preload (7.3004-7.3031)
Bearing cap bolt torque (27-38 ft-lb)
Lock plates on bearing caps (13-19 ft-lb)
ring gear to the differential (51-61 ft-lb)
