Author Topic: 1950 International shop rod 1.0  (Read 83562 times)
Re: 1950 International shop rod 1.0
« Reply #15 on: June 24, 2018, 10:04:15 PM »
cab mounted to new chassis
ford v8s and international vs chevy and chevy V8 there is about 6" difference in the wrong way.  had to cut into the international fire wall.  hacked and patched and done, will deal with it more when doing the interior.  i knew anyway i did it i would not like so it just got done.
looks good as a rolling.  hoping the fuel tank and canister play nice when its time to mount the bed, but steering brakes wiring first so it can turn itself around in the shop bay.
most parts in hand minus exhaust and glass.
« Reply #16 on: June 25, 2018, 10:59:41 PM »
has functional steering and brakes tonight.
« Reply #17 on: June 27, 2018, 08:22:54 AM »
after 2 hours of chasing wires and book reading with no start
MikeMike stopped over to use the lathe and some how stumbled upon Ford uses the same exact connector for the ignition switch as they do for one of the smart distribution box plugs and i had them reversed.  what a terrible POS ford is.
back running! bah!
« Reply #18 on: June 28, 2018, 10:12:16 PM »
back on the lift tonight got rear slider bolts un froze, 4 new rotors, fedex bring pads tomorrow.
needs wipers and a sticker
« Reply #19 on: July 01, 2018, 10:20:39 PM »
fires from inside cab with a key.  that took a lot of work.  under hood harness trimmed down.  A little more work under dash as required keeping the cluster and parts of the old ignition switch, two power modules.  bah!
« Reply #20 on: July 01, 2018, 10:28:25 PM »
where do you have the window AC stashed? I don't remember this shop feature (from fb)
looking good!
« Reply #21 on: July 01, 2018, 10:51:06 PM »
feature was cut in this morning.  sitting on top of the fridge with a new hole though the OSB to caved in addition lol
« Reply #22 on: July 01, 2018, 11:06:07 PM »
AC now!.. I’m jealous
« Reply #23 on: July 01, 2018, 11:15:51 PM »
the one in my appartment is WAY over sized, i wish i had the effort to carry it over.  probably be much better in the larger space.  the newer unit that i stuck in i bought for the trailer and is smaller.   Has a remote control which id love at home.
left it cranking tonight, see how it is tomorrow.  i expect to take a half day.  need to run out to Palmyra to grab a new 4l60 pump
« Reply #24 on: July 02, 2018, 09:02:27 PM »
If i leave the floor hatch open I get the AC from the apartment falling down..
No man door so any entry exit I’m dehumidifying Monroe county..
« Reply #25 on: July 03, 2018, 10:32:00 PM »
drove out of the shop tonight.
new head liner installed
bench seat installed (needs to be lifted up about 2-3")
summit copy of flowmaster 40 installed
« Reply #26 on: July 08, 2018, 07:57:12 PM »
4.6 sounds good
played with some wiper motor parts tonight for a bit but not much accomplished.
« Reply #27 on: July 12, 2018, 10:40:07 PM »
cooling system complete and filled.
steering and trans coolers, Fan mounted, steering res mounted.
« Reply #28 on: July 13, 2018, 10:52:05 AM »
I need to stop and get some pictures of this one. My Grandpa seemed mildly interested in it before you ever started working on it.
« Reply #29 on: July 13, 2018, 12:50:41 PM »
hope to start working on finishing up the electrical and get the bed mounted this weekend.  shouldnt be long for a test drive since its already plated and insured.
