Author Topic: Green monster  (Read 121114 times)
Re: Green monster
« Reply #300 on: May 13, 2019, 12:44:56 AM »
Re: Green monster
« Reply #301 on: May 13, 2019, 06:53:08 AM »
hope its a system that is better than all the RV guys at work complain about- nothing but false reads and problems with those things.
Re: Green monster
« Reply #302 on: May 13, 2019, 09:09:46 AM »
Good for 8 driving hours so far.
Interface is shit, but instructions are good.
Re: Green monster
« Reply #303 on: May 13, 2019, 10:51:06 AM »
For 10 valvestem caps? Not likely.
More likely if I’m doing it a dozen times per year or if I have an issue sometime when I didn’t bother to swap.
didn't realize they were caps.
When you said TPMS, I thought it meant you had to break bead, replace valve with TPMS inside the tire, seat bead, etc...
So, I take back what I said.  That's easy.
« Last Edit: May 13, 2019, 10:55:49 AM by M »
Re: Green monster
« Reply #304 on: May 13, 2019, 10:53:19 AM »
Worst part by far was not having an adequate impact. Need to get some 1/2” air plumbed and a 3/4 or inch gun if I’m ever doing this again.
This guy works but I’m really feeling it.
https://uploads.tapatalk-cdn.com/20190511/d27ebcf41f8b2a9c9c8458bb493d0cdc.jpg
Attached photo is coming soon!   1,800ft/lbs.   Reported to be out by June.
https://www.milwaukeetool.com/Products/Power-Tools/Fastening/Impact-Wrenches/2867-20
« Last Edit: May 13, 2019, 10:55:05 AM by M »
Re: Green monster
« Reply #305 on: May 13, 2019, 11:03:19 AM »
wrong color, and probably a little more than ~$180
Re: Green monster
« Reply #306 on: June 03, 2019, 12:35:15 AM »
Bunk flipped today after the rolling w trip with Sarah. She’s small, but that bunk was way, way, way smaller. Way.
First major interior mod. And clears the way for eventual rear pass through.
Pulled and resealed bunk windows. Need to patch old poorly repaired damage on the cab roof too, as I’d suspected. It was one of three leaks I found. Windows of course were the other two.
Will need to do some interior trim work to replace damaged cardboard backing from those leaks.
Need to do permanent wiring, but finally put up a couple 12” led lights too. Huge improvement over one reading lamp.
Current cab roof insulation is 3/4” open cell foam. How much improvement would some foil back something add, you think?
Re: Green monster
« Reply #307 on: June 03, 2019, 06:37:23 AM »
how many air fresheners do you have in that thing
Re: Green monster
« Reply #308 on: June 03, 2019, 08:32:28 AM »
Went from one to zero with the hanger i pulled out, and it was older than dirt. International must have some secret sauce - it _should_ smell. But it doesn’t.
I guess it dries quickly. No mold found.
Re: Green monster
« Reply #309 on: June 03, 2019, 08:59:12 AM »
I just really lol'd, twice!
Re: Green monster
« Reply #310 on: June 03, 2019, 10:08:06 AM »
It's been a long time since I've done fiberglass work. hopefully whatever they put over the top of that hole doesn't get too much in the way of fixing it a bit better. I think it may be a trailer roof patch painted over. It's paper thin whatever it is.
Re: Green monster
« Reply #311 on: June 03, 2019, 10:44:08 AM »
That made me laugh for real.
Re: Green monster
« Reply #312 on: June 03, 2019, 11:17:17 AM »
Am I missing something? Maybe a pic of a pile of air fresheners? Forgive my slow wit...
Re: Green monster
« Reply #313 on: June 03, 2019, 11:35:44 AM »
I think they think it stinks? I really don't get it either ¯_(ツ)_/¯
Re: Green monster
« Reply #314 on: June 03, 2019, 11:45:05 AM »
good refresher on typical 'glass repair.
https://www.youtube.com/watch?v=SsoKAHU5xUw
