Author Topic: Green monster  (Read 121161 times)
Re: Green monster
« Reply #255 on: September 06, 2018, 03:43:21 PM »
I saw this sweet rig the other day.
Re: Green monster
« Reply #256 on: September 06, 2018, 07:02:13 PM »
Not looking good to fix cab lift before rolling w. Hopefully it’s fine!
Re: Green monster
« Reply #257 on: September 08, 2018, 10:17:24 PM »
~8.5mpg on 219 from the Rex to rolling w and back. Other numbers to come. Finally got a odometer correction, it’s about the same as the speedometer, unsurprisingly.
Re: Green monster
« Reply #259 on: September 17, 2018, 09:13:27 PM »
surprised I didn't note oil change in this thread or on receipts.
just put numbers in. best tank 8.6, worst 7.6 across almost 4000 miles/500 gallons
7.84mpg since the first time I topped it off in April.
I would usually get I think 10.5-11 towing the enclosed with my Ram. Ram lifetime economy at 12.34 through March '18
Between fuel, mods to date, and purchase price, I'm almost surprised at how fast things add up.
SB406
  • Newbie
Re: Green monster
« Reply #261 on: September 21, 2018, 06:52:12 PM »
Down to STUMP on passenger side before the rain.
Now I’m gonna remount a brolite tire and poke a cab hydraulics tomorrow before I leave.
Re: Green monster
« Reply #262 on: September 21, 2018, 07:16:03 PM »
What's your method for removing decals?
Re: Green monster
« Reply #263 on: September 21, 2018, 08:31:04 PM »
some heat & peel, the yellow and black come off well that way. The white is really brittle. Today on the white was mostly spray with adhesive remover and scrape with razor. I dropped the razor and broke it, and the fresh blade is now all about carving into the paint. need to dull the new blade on some steel or something.
Re: Green monster
« Reply #264 on: September 22, 2018, 01:58:45 PM »
Line from the ram to the latches rubbed through at the hinge.
Re: Green monster
« Reply #265 on: September 22, 2018, 06:45:03 PM »
PB blaster takes spray paint off if that helps
Re: Green monster
« Reply #266 on: September 24, 2018, 10:54:47 PM »
Had to change a fuel filter in this on my way home last night, made it to the Petro at exit 41 after listing speed and power for the previous 15 or so miles.
Almost had to spend the night there but the second service tech knew how to do better interchange lookup and found a part with 23 in stock. I bought 3.
Then I had some electrical smoke just past 332. Was the cobbled hvac fan. Didn’t pull the dash to investigate. Fan didn’t previously do much anyway so not much loss in function. Have run the fan for hours previously so precipitating change unknown. Obviously not fused when rewired. Maybe motor just failed.
Re: Green monster
« Reply #267 on: September 25, 2018, 08:23:39 AM »
left you a box of my old trailer interior lights on your RAM.  toss them if you dont want them.
Re: Green monster
« Reply #268 on: September 25, 2018, 09:12:21 AM »
I noticed it when I got home. it stayed put. Thanks, I think those are probably good spare bulbs for existing interior lights if nothing else
Re: Green monster
« Reply #269 on: October 09, 2018, 05:55:35 PM »
I think I’m settled that rad will come out after returning from rolling W race on oct20th. Hopefully enough time to make shipshape for aoaa trip first week of nov.
Please hope for good weather.
