Author Topic: JEEPWERX CJ7 Buggy Style  (Read 75377 times)
Re: JEEPWERX CJ7 Buggy Style
« Reply #300 on: November 26, 2014, 12:56:29 PM »
« Reply #301 on: November 26, 2014, 12:59:21 PM »
Ok those look to be the "performance" grade.
« Reply #302 on: November 26, 2014, 01:01:59 PM »
Since you reminded me about my new shocks... let's get together some night and I'll take you up on the offer of bending up some quick bro tubing based on your #'s.
And we can calculate spring rates based on Air shock pressures.
I'll buy some cheap whiskey!
« Reply #303 on: November 26, 2014, 01:03:02 PM »
i dont know, maybe not.  this is very confusing!  two shaft sizes for 2.0's also.  you got bigger ones, good.
my shock pressure filler got broken last rausch trip   :(
« Reply #304 on: November 26, 2014, 01:06:59 PM »
Mine is operational.
« Reply #305 on: November 26, 2014, 01:07:43 PM »
Bigger shaft is always better. Right?
« Reply #306 on: November 26, 2014, 02:53:47 PM »
thats what she said....
« Reply #307 on: December 26, 2014, 09:05:07 PM »
http://www.driveshaftsuperstore.com/Transfercase_and_differential_end_yokes.htm
Anyone ever deal with this manufacturer before?
I was looking for 1330 yokes for the dana 300. But it looks like they make a 1350 high clearance yoke instead.
I wasn't planning to install 1350 yokes on the dana 300 (figured the stock output is already weak enough)
but this might be a good deal.
I have binding at the rear output if i let it fully droop out.
I've always had an output upgrade on the long to do list. But it most likely won't happen before KOH.
I'll just bring a spare.
« Reply #308 on: December 26, 2014, 11:32:50 PM »
center limit strap would probably cure all with out limiting flex....
« Reply #309 on: December 27, 2014, 01:21:11 AM »
they made the rear shaft for the J truck  (before vic opened his shop)
« Reply #310 on: December 27, 2014, 07:16:49 AM »
Mike,
I've been running a center limit cable, with the plan to replace with a strap of the correct length after new shafts were made.
Actually have new strap and adjustable mount on the bench ( for about 1 year now)just looking to gain as much clearance as possible because my rear shaft is on the short side.
Good to know Gif
Thanks
« Reply #311 on: January 04, 2015, 08:36:33 PM »
It was a productive saturday:
Finished rear body panels
New Ruff Stuff 14 bolt Pinion Guard and Truss Support modified, Bolted and Welded in.
New Poly Performance limit strap and mounts installed in center of rear axle.
New Rear Round Driveshaft made. (Waiting on new U joints to arrive for re-install)
Sunday was less productive...
but still a good day!
Rear Diff cover bolts replaced
Air Bumps installed
Measure and layout Air Bump landing pads
Ordered spare pinion yokes and Dana 300 Yokes, Drive shaft u-joints and u-bolts
(parts bin was empty)
« Reply #312 on: January 04, 2015, 08:50:02 PM »
Cora was busy working on new wrap design.
« Reply #313 on: January 04, 2015, 09:12:56 PM »
Ooh! I like that one best.
« Reply #314 on: January 04, 2015, 10:29:44 PM »
Not that you asked, but the rear wheel "opening" looks too small.
Like the graphics!
