Author Topic: The Profender 4-seater  (Read 132374 times)
Re: The Profender 4-seater
« Reply #285 on: June 06, 2012, 01:55:35 PM »
The one bolt that is thru the floor on the front side you cant get a cutoff wheel or sawzall to. The other 3 are fine. No need to pull anything to get to them all. I can tighten them with a wrench from under the pile.
it needs "give" both ways, otherwise it may as well be bolted in solid.
Why would solid mounted be bad for a divorce mount t-case? There is no need for "give" on a divorced mount.
« Reply #286 on: June 06, 2012, 04:57:22 PM »
It is a give and take relationship
« Reply #287 on: June 12, 2012, 04:21:05 PM »
Raining tonight, so no fence work. Putting the front end of this pile back together tonight.
« Reply #288 on: June 18, 2012, 08:37:57 AM »
3 leaky beadlocks, from te inside of the wheel. Im going to try and slime them to see if that cure the leaks.
« Reply #289 on: June 18, 2012, 09:04:45 AM »
If its at the bead I'll be surprised if it works.
« Reply #290 on: June 18, 2012, 09:05:48 AM »
Its leaky welds from the backside of the weld on ring (I did not weld them), not the actual tire bead.
« Reply #291 on: June 18, 2012, 09:08:54 AM »
Ah, misunderstood. No clue if that'll work. Would be neat.
« Reply #292 on: June 18, 2012, 09:11:54 AM »
DIY with cracked welds after 40 race miles, hmmm. interesting.
« Reply #293 on: June 18, 2012, 09:12:10 AM »
If slime can seal up Smikes holy TSLs then I think it can do just about anything. Hahahahah
« Reply #294 on: June 18, 2012, 09:13:05 AM »
I will be surprised if they are still on this rig next season.
« Reply #295 on: June 18, 2012, 11:19:52 AM »
i moved those TSL yesterday, and every one of them was still hard with air!
« Reply #296 on: June 18, 2012, 01:38:31 PM »
sweet
« Reply #297 on: June 18, 2012, 03:09:36 PM »
Don't let the air out of them without ventilation in the shop. You may asphyxiate yourself!
« Reply #298 on: June 18, 2012, 03:14:48 PM »
i filled my enclosed trailer with tires sunday.  like filled, tires, blown motor, boxes and parts, and moved to storage under the apt
i just counted, i am up to 48 tires i currently own, i am sure there are more bah!
« Reply #299 on: June 18, 2012, 03:16:32 PM »
need to dump them?  i know a place
