Author Topic: The Profender 4-seater  (Read 132211 times)
orange anchor
Re: The Profender 4-seater
« Reply #210 on: April 13, 2012, 10:33:14 AM »
good luck Ryan,  Liz enjoy the paradise of have the new hauler.
« Reply #211 on: April 15, 2012, 06:28:58 PM »
How'd the 024 buggy do?
« Reply #212 on: April 15, 2012, 06:42:23 PM »
had some driveshaft issues, .5 lap DNF and needs a rear pinion seal at least. nut came off the rear pinion, and off the midship yoke of the rear shaft if I understood correctly.
« Reply #213 on: April 15, 2012, 09:28:59 PM »
Made over 9 miles until the shaft failure. Then another 200 feet until the other shaft failure.
« Reply #214 on: April 15, 2012, 09:53:19 PM »
i guess we blew by you guys so fast liz didnt even no it was us until a few seconds of thought later  8)
Liz_rn
« Reply #215 on: April 15, 2012, 10:02:50 PM »
Yeah I was totally spaced out and not paying attention :)
« Reply #216 on: April 16, 2012, 06:33:38 AM »
How was the new trailer?
« Reply #217 on: April 16, 2012, 06:47:54 AM »
awesome!
Liz_rn
« Reply #218 on: April 16, 2012, 07:12:18 AM »
Even better than awesome!
« Reply #219 on: April 16, 2012, 04:06:03 PM »
fuckin sweeeeet
« Reply #220 on: May 07, 2012, 12:03:05 AM »
this hog is 4-5" lower in the front.  should take more rate well, and have less of -2" of preload ryan :)
bumps, rear coil mounts, rear sway bar.
« Reply #221 on: May 08, 2012, 12:37:40 AM »
im confused by our sway bars.  seems like half the hardware is missing.  yours is on.
« Reply #222 on: May 08, 2012, 08:52:28 AM »
just have rear mounts and front bumps to move.  the rear bumps may work as is and are set up good.  just ticks the sway bar a little.
« Reply #223 on: May 08, 2012, 09:01:18 AM »
Can I get a pro fender shock absorber pen?
« Reply #224 on: May 08, 2012, 09:03:21 AM »
I have no pens.
What is missing from the sway bar kits? I will call again and leave another message.
