Author Topic: narrow track axles, pizza cutter ~33s  (Read 3442 times)
Re: narrow track axles, pizza cutter ~33s
« Reply #15 on: October 26, 2016, 06:24:43 PM »
possible tire source (yes I know how heavy they are)
http://www.ebay.com/itm/Set-of-4-Michelin-XZL-8-25-R16-/182174882085?hash=item2a6a781925:g:HbMAAOSwzJ5XZJzJ&vxp=mtr
having dug into things, I think the offset rear of a quadratrac jeep would be good - I can place the engine to minimize side to side driveline angle.
looks like I may have to mix n match to get
- 2.72
- quadratrack offset
- narrow track
It appears that the QT do come narrow but have mainly (only?) 3.54s
« Reply #16 on: October 26, 2016, 06:46:00 PM »
ide buy a set of those ;D
« Reply #17 on: October 26, 2016, 08:18:46 PM »
Probably head up once I find axles.
« Reply #18 on: October 26, 2016, 08:41:17 PM »
$225 to ship them?
« Reply #19 on: October 26, 2016, 11:26:35 PM »
Not unreasonable with a boarder crossing. Or just spend a day driving up & back with a stop for fun of some sort in Toronto.
« Reply #20 on: October 31, 2016, 10:26:15 AM »
Plus if you drive up, you'd probably get the chance to select the tires you want, pull all 70% tread ones instead of 50%
« Reply #21 on: October 31, 2016, 12:37:36 PM »
REF:
amc 20 carrier break 2.73/307
dana 30 carrier break 3.54/3.73
I think I've found what I need, mix n match - but I'd rather get shit from you guys if you don't want to sit on it so any specifics would be great.
Guy near Rausch has a disk brake d30 2.73 narrow track asking $400, no calipers. figure I'll offer 2?
same guy is asking 350 for a complete wide track 2.73 20.
Buffalo dude is asking a grand for a quadratrack 20, figure I'll offer him a hundred bucks while trying not to laugh in his face and see where that goes, then swap gears to match?
I'm seeing gears and carriers for 20s for around 125ea regardless of ratio, so probably even money and less work to swap gears and resell 3.54s and a carrier than swap into another axle.
« Reply #22 on: October 31, 2016, 01:11:39 PM »
YJ axles too wide i assume
not that i want to contribute to this terrible idea lol
« Reply #23 on: October 31, 2016, 02:08:08 PM »
Doesn't this thing burn oil like crazy?
« Reply #24 on: October 31, 2016, 02:17:16 PM »
current motor needs rebuild, current trans useless. hence: delete everything and start over.
CJ narrow track with 2.73s are the only good option I've found. target wms-wms ~50"
« Reply #25 on: October 31, 2016, 05:51:42 PM »
theres a ford 7.5 laying in my driveway if it does you any good
« Reply #26 on: October 31, 2016, 08:53:24 PM »
what gears on that ford 7.5?  ill take it if free
« Reply #27 on: October 31, 2016, 09:18:30 PM »
door code is hard to make out but i believe its a 6 7/8"s with 3.45 s
« Reply #29 on: November 01, 2016, 05:24:56 PM »
not quadratrack rear not 2.73.
have located what I need - just need to go down to Rausch Creek area and get them.
I also picked up some roller wheels & tires today. I'll be doing some router and hand drill precision machine work on them to open the center bore and drill the right pattern, but for rollers & test fit for tire clearance it couldn't be beat for his asking price ($120) - much less when he offered them to me for $40 when I got there. Makes up for the toolbox guy haha
I figure I can make a template out of a front rotor pretty easily and make them fit in less than an hour a piece. bald 265/70r17 on horribly corroded alloys off an f150.
