Author Topic: Here we go again (roofing content)  (Read 25571 times)
Re: Here we go again (roofing content)
« Reply #15 on: October 14, 2016, 05:36:49 PM »
Kim would not approve...  :o
« Reply #16 on: October 14, 2016, 07:23:42 PM »
No flashing up at that complexity. All shingle.
Ridge vent is ridge vent stuff.
Other side is 1/3 to 1/2 stripped. Will be a challenge to finish before Sunday rain. I think the soft wood is due to attic humidity. One area now exposed seems to just be somewhat delaminated. No rot, no leak.
« Reply #17 on: October 15, 2016, 04:30:55 PM »
so much dry rot on the original house structure. I think all of that is going to get redecked. Hope the rafters are still solid.
still need to strip the roofing off the 4/12. Looking at it, I'm expecting a lot of either rotten or unglued ply, and maybe some soft rafters. hopefully they're just sagging for fun and I don't need to rebuild anything extra....
« Reply #18 on: October 15, 2016, 04:31:29 PM »
oh yeah, totally not finishing by Sunday. and it might kill me.
but it's probably better than my day job - shame about the hours & pay though.
« Reply #19 on: October 15, 2016, 08:25:27 PM »
Just need to resheet pretty much all of it, ventilate and insulate it, and lay roofing!
« Reply #20 on: October 15, 2016, 08:44:51 PM »
This isn't the same section we did in 2011, is it?
« Reply #21 on: October 15, 2016, 08:58:21 PM »
it's the rest.
« Reply #22 on: October 15, 2016, 09:45:46 PM »
whew!  ;D
« Reply #23 on: October 16, 2016, 10:07:52 AM »
Look like it'll be dry today! :D
« Reply #24 on: October 16, 2016, 11:34:45 PM »
decent overnight too. good since it's getting left as it landed.
learned that the 50" bar draws a decent amount. Batteries were sitting at 8-9 volts by the dash gauge after about 5 hours. I didn't do the math but I know that's bad...
almost fully sheeted. Have to make 2 more stack holes and trim some corner pieces, and make sure I don't forget to find wherever I buried the bathroom vent before it gets a bit late for that.
I think I can get it done tomorrow. If not, damn close - ridge shingling takes way more time than I remembered.
Good times!
« Reply #25 on: October 17, 2016, 08:26:58 AM »
i have a couple loose bars that i just run off a battery charger if you need to borrow
« Reply #26 on: October 17, 2016, 11:50:29 AM »
That went poorly.
Placed buckets under leaks from 3-3:30 and then laid all my rolled product in the rain until about 5:00
Then I turned off all my alarms and said I was sleeping until I wake up. Probably a bad plan with thunder forecast 3 hours from now bit I didn’t really care at the time.
I guess I’ll go see if it’s dry enough to do anything with
« Reply #27 on: October 17, 2016, 01:09:13 PM »
big blue tarp
« Reply #28 on: October 17, 2016, 01:55:03 PM »
rain in that quantity wasn’t expected. Big blue tarp on the ground catching debris.
Oops
« Reply #29 on: October 17, 2016, 01:58:58 PM »
my ignorance, but how does metal roof cost compare to shingles?
