Author Topic: 1925 Roadster Pickup  (Read 33994 times)
Re: 1926 Roadster Pickup
« Reply #30 on: June 22, 2016, 10:51:41 AM »
looks loud lol
« Reply #31 on: June 22, 2016, 04:41:50 PM »
looks loud lol
I have a plan for that when i finish weld them
« Reply #32 on: June 22, 2016, 04:49:35 PM »
thanks guys
« Reply #33 on: June 24, 2016, 09:01:27 AM »
1930's Model A truck bed is hard to find in good shape.  And if I did find one i was going to modify it anyways..
So decided to build my own.
I used a bead roller to give it the factory look.
started with the sides and then the floor.
« Last Edit: June 24, 2016, 09:04:22 AM by gif »
« Reply #34 on: June 24, 2016, 09:07:25 AM »
« Last Edit: June 24, 2016, 09:09:41 AM by gif »
« Reply #35 on: June 24, 2016, 09:12:17 AM »
« Last Edit: June 24, 2016, 09:43:52 AM by gif »
« Reply #36 on: June 24, 2016, 09:55:05 AM »
what did you use to make all those small cuts on the bend?
it looks awesome...
« Reply #37 on: June 24, 2016, 10:42:32 AM »
it looks awesome...
cut off wheel on my grinder and a steady hand...
« Reply #38 on: June 26, 2016, 08:33:08 PM »
Tranny tunnel built from a water tank
« Reply #39 on: June 27, 2016, 10:58:08 AM »
Killin it, looks awesome
« Reply #40 on: June 27, 2016, 05:57:36 PM »
car needed more foot room.   so i built some side scoops using 22 gauge sheet steel.    This gave me a nice rolling bend that follows the sweeping curves of the car.
« Last Edit: June 28, 2016, 08:26:15 AM by gif »
« Reply #41 on: July 01, 2016, 07:45:23 PM »
fuel tank
this is 10"x36" stainless tank   The tank is typically used up high in sand rails and 2wd buggies.
I wanted it tucked under the bed hidden away.
However the fill neck and line ports were in the wrong spots.  So i had to move them.
I also did not like the straps that these use.   i made new mounts. had to build a jig to roll the 3/8x5/8 bar stock.
« Last Edit: July 01, 2016, 09:29:04 PM by gif »
« Reply #42 on: July 01, 2016, 07:56:24 PM »
with the bed installed.
gas door with custom made hinge.
« Reply #43 on: July 01, 2016, 08:54:57 PM »
Haha, it's almost a shame that you can't see the tank.  Nice!
carchameleon
« Reply #44 on: July 06, 2016, 09:40:10 AM »
this thing looks awesome, great work
