Author Topic: bro 574  (Read 7917 times)
Re: bro 574
« Reply #30 on: April 19, 2016, 09:42:06 PM »
Only looked at Nuway, rock auto and then autozone online.
Don't need one to get me rolling. but wanted one in the trailer for spare.
Dorman part was like 58.00
Autozone lists for 98.99
Ford will be 150.00 I'm sure
Summit lists them as well.
Re: bro 574
« Reply #31 on: April 19, 2016, 10:02:34 PM »
I mean I can try and order these if they are that scarce.
Re: bro 574
« Reply #32 on: April 19, 2016, 10:08:27 PM »
Sounds like they have become scarce. Guys wadding up their trucks are gonna need these sooner or later.
They don't hold up to corrosion like the Axle Beams do, so junkyards around here aren't full of good ones.
Re: bro 574
« Reply #33 on: April 20, 2016, 07:50:13 AM »
Do you have to run the stock I beam or can you run an aftermarket like this one http://simotorsportsinc.com/images/ibeamkit.jpg
Re: bro 574
« Reply #34 on: April 20, 2016, 07:59:26 AM »
Stock stock stock.
The issue with most aftermarket suspension parts for the ranger IMO is they they typically do something we don't want... Lift or Lower the vehicle.
What does this kit do?
If there is a stock replacement out there we may need it at some point.
Re: bro 574
« Reply #35 on: April 20, 2016, 08:35:19 AM »
i couldnt find anything aftermarket with same stock ride hight
changing the geometry with lift or lowering parts does not meet the rules
both of Bills are swiss cheese so he will be searching- i gave him a heads up they are hard to find.  that ebay place claims they have some
Re: bro 574
« Reply #36 on: April 20, 2016, 12:32:29 PM »
Re: bro 574
« Reply #37 on: April 20, 2016, 01:33:44 PM »
CL fail, only got one extra wheel from the guy, and one of the 5 has egged holes from loose lugs.  fail on my part.  still good buy for 150$
2 new snows mounted
2 30% snows mounted
one rando
Re: bro 574
« Reply #38 on: April 22, 2016, 09:14:13 AM »
gutted interior minus dash last night.  going to need some floor patches on driver side!
Re: bro 574
« Reply #39 on: December 05, 2016, 09:14:27 AM »
this thing is the new mobile outdoor storage.  flat bed currently holding (1) 4.0L, (1) 2.5L, (2) 231's, (1)242, (1)AW4, (1)42RE
needs heavier rear springs.  flat bed sitting on rear tires
Re: bro 574
« Reply #40 on: December 05, 2016, 09:46:20 AM »
With a gangsta lean, major tire rubbing  ;D
Re: bro 574
« Reply #41 on: December 05, 2016, 10:52:42 AM »
we thought putting smaller tires on rear would help, but bed still sitting on smaller tires.
id guess its over loaded only by 1000lbs or so    ::)
Re: bro 574
« Reply #42 on: December 05, 2016, 11:04:38 AM »
Easy fix: donate 1 complete drivetrain to me! Lol
Re: bro 574
« Reply #43 on: December 05, 2016, 11:43:17 AM »
stacked wooden block bump stop extensions. matches bed construction
Re: bro 574
« Reply #44 on: December 05, 2016, 02:02:36 PM »
i was actually looking at the car battery pile to see if i could stuff two batteries in between the frame and spring plate.
my blocking selection is limited and mostly used and cared for
the other suggestion was to pick up the chain saw and make bed cutouts for the tires.  too many deck screws though and would require more work to unload.
the 2.3 and clutch took it fine.
