Author Topic: Whatever... SOLD  (Read 11088 times)
Re: I need a name...
« Reply #30 on: April 14, 2015, 08:13:34 AM »
Previous owner located another key.  Will be on it's way via USPS.  Yea?!
« Reply #31 on: April 19, 2015, 07:05:40 PM »
Key sent from previous owner no-work-ie.   :(
Tahoe key returned.
Junkyard ignition cylinder will stay.  Spare key screwed to chassis.
FLX sticker affixed.  It's now official.
Kinda liking "Whatever"...
« Reply #32 on: April 25, 2015, 09:10:01 PM »
RC trip broke a rear shock mount (poor welds), shock shaft, and tore a break line off.  Parts on order...
« Reply #33 on: April 25, 2015, 09:31:47 PM »
If a shock mount was poorly welded, what else should you double check?
« Reply #34 on: April 25, 2015, 09:48:05 PM »
Nothing?  Until it breaks?  ;D
Re: Whatever...
« Reply #35 on: May 03, 2015, 06:45:25 PM »
Back to wheeling status.
New brake hose, brake line, shock, installed.  Shock mount fabbed from 3/16" scrap.  Extended hard line and bracket another 2 inches to allow full droop without stretching hose.  Also installed new bump stop extensions and trimmed split poly bumps.
Re: Whatever...
« Reply #36 on: May 26, 2015, 07:48:09 AM »
After this past RC weekend...
New rear bump stop that I could not seat properly vacated it's previously damaged jouncer cup.  Flipped it upside down and wired-tied in.  Good for the remainder of the weekend.  Will attempt repair of existing cup and install properly.
The previously repaired rear ARB solenoid failed.  Not enough "meat" on the wire left to effect another repair.  Swapped front/rear for the weekend because I prefer to have a rear locker.  Mikemike may have a replacement on hand...
Re: Whatever...
« Reply #37 on: May 26, 2015, 08:29:53 AM »
I think I have a spare solenoid in the YJ toolbox if you need one to test..
Re: Whatever...
« Reply #38 on: May 26, 2015, 09:35:51 AM »
I bought a spare I didn't need, Mark's covered!
Re: Whatever...
« Reply #39 on: May 28, 2015, 07:15:54 AM »
Thanks Mikemike!  And thanks for the offer Arie!
Re: Whatever...
« Reply #40 on: May 30, 2015, 02:06:25 PM »
Jouncer cup removed, deburred and reinstalled.  Bump stop deburred, lubed, and re-installed correctly.  ARB solenoid swapped in.
Let's go wheelin!
Re: Whatever...
« Reply #41 on: June 03, 2015, 10:47:54 AM »
Performance decal added
Re: Whatever...
« Reply #42 on: June 05, 2015, 07:57:54 PM »
Lmao
Re: Whatever...
« Reply #43 on: June 09, 2015, 09:17:37 AM »
Custom radio "install"  ;D
Re: Whatever...
« Reply #44 on: September 08, 2015, 06:17:54 PM »
This thing got a little love today. One new axle u-joint and two new wheel bearings installed. Tightened frame side link bolts. Ready for more wheelin'!
