Author Topic: Sprinter issue  (Read 3891 times)
Re: Sprinter issue
« Reply #30 on: April 02, 2015, 08:22:48 PM »
Prove that I am not a robot… Everything except for interior and the big parts is out. Exhaust, 75% of driveshaft, death and fuel tanks.
The frame is also cut off upfront, and engine is almost – if not completely – disconnected from the chassis. Just need to roll the van back on the trailer, unbolt leaf springs, shocks and brake lines. Then drop the rear remove cradle bolts and strut nuts and lift the front to slide the drivetrain out the nose.
The small pieces remaining are the four good doors, anything in the – like the head unit or cluster or ignition or shifter, and I did not remove the throttle by wire Excelerator yet
Good removed parts so far include: complete fuel tank
Complete DEF tank
Complete exhaust
Both mirrors
Coolant overflow tank
Headlight, broken mounting tabs
ABS pump
Brake master and booster
Interior battery
I think that's about it. I also pop the breaker on the rear exterior outlet of the building – the M Glo compressor seems to be toast.
I dictated this entire thing on my way home, and didn't proofread anything. I hope it's readable!
Re: Sprinter issue
« Reply #31 on: April 04, 2015, 08:28:13 PM »
Everything but dash parts and seats stripped. 13hr into it.
Dropped the slider and crunched a corner, wind took it. It let loose when I wasn't expecting and then a gust improved the situation. Really pissed me off. Everything else went quite well though.
Off jackstands and ready to tie down.
Winch did WORK scooting the shell forward. Welds on the winch mount very proven. I was standing back-even with a snatch block in play. I should have videoed...
Re: Sprinter issue
« Reply #32 on: April 05, 2015, 08:58:19 AM »
drop that in your WJ and call it damn day!!!!
WOW..
ill be up there 8am tomorrow to move boat/dump truck inside.. will have some room to maneuver..
Re: Sprinter issue
« Reply #33 on: April 05, 2015, 01:12:45 PM »
All the important interior goodies are in the airbag between the seat bases.
I wanted to get the glove box, but it's all involved with the passenger airbag... I did not get into the column, either.
It would be awesome if things were sorted out and ready to strap down and hit the scrap yard first thing Tuesday on the way to work...
There's scrap to the side of it and a mix of scrap garbage and good parts in the back.
Note condition of carrier bearings on the driveshafts. They all got fucked when the drivetrain moved back.
Re: Sprinter issue
« Reply #34 on: April 06, 2015, 02:53:46 PM »
sweet lot chop
Re: Sprinter issue
« Reply #35 on: April 08, 2015, 09:31:09 AM »
Scrap prices are truly sad :(
https://youtu.be/h94W6ecZ-MY
Re: Sprinter issue
« Reply #36 on: April 08, 2015, 09:35:39 AM »
ya it was like 170 a ton last time i went, not even worth it for a yj carcus, other than getting rid of it
Re: Sprinter issue
« Reply #37 on: April 08, 2015, 09:39:19 AM »
how much did it weigh stripped like that?
Re: Sprinter issue
« Reply #38 on: April 08, 2015, 09:45:39 AM »
3070# @ $110/GT or about $98/ton :(
Re: Sprinter issue
« Reply #39 on: April 08, 2015, 09:50:52 AM »
wow thats crap 98 /ton  the crack strollers must really be hurting
Re: Sprinter issue
« Reply #40 on: April 08, 2015, 09:52:03 AM »
oil price dictates steel price....
were in a low for both right now
Re: Sprinter issue
« Reply #41 on: April 08, 2015, 10:01:55 AM »
sure makes me not want to clean up.
It didn't really register with me when I brought a little bit of stuff in with Gus when I had to get him weighed how low the steel price was.
I remember when I was scrapping things more regularly (when gas was $4 and diesel was near $5...) that it was more like $230/GT. Pretty crazy.
Re: Sprinter issue
« Reply #42 on: April 08, 2015, 10:46:19 AM »
best i got was 270 a year or two ago, crazy
Re: Sprinter issue
« Reply #43 on: April 08, 2015, 11:56:26 AM »
Not good info for my spring cleanup plans. :(
Re: Sprinter issue
« Reply #44 on: April 09, 2015, 04:42:12 PM »
I got a little over $100 when I scrapped around 150lbs of scrap. However around 38lbs of it was from my truck's original copper radiator.
