Author Topic: 2000 jetta TDi  (Read 31887 times)
Re: 2000 jetta TDi
« Reply #120 on: September 14, 2015, 11:08:53 AM »
bump for Nick
current issues
exhaust rattle / temp fix of failure before cat
has had a wheel bearing hum since bought, cant find which corner, replaced loose front driver, still noise, all tight.
hard starts below 10F, probably needs a harness.  plugs changed.
needs NY inspection
wont have time till Oct to deal with anything on it, still daily driving.
Re: 2000 jetta TDi
« Reply #121 on: September 22, 2015, 09:07:05 AM »
power steering whine twice in the last 2 weeks found low fluid and filled then ok.  guess she has a leak somewhere.
boo
Re: 2000 jetta TDi
« Reply #122 on: October 02, 2015, 09:56:27 AM »
ah, the joy of cold hard starts has begun.  need to work on that bah.
Re: 2000 jetta TDi
« Reply #123 on: October 04, 2015, 07:55:52 PM »
put a toggle switch in for the glow plugs, works mint!
Re: 2000 jetta TDi
« Reply #124 on: October 04, 2015, 09:32:08 PM »
On a new relay? Must be a bad temp sensor somewhere if not. Weird.
Re: 2000 jetta TDi
« Reply #125 on: October 04, 2015, 09:34:31 PM »
completely bypassed and just put a 50 amp fuse and relay to the 2 wire glow plug harness.  no idea what the issue was, not worth my time to dig
Re: 2000 jetta TDi
« Reply #126 on: October 05, 2015, 11:08:40 AM »
:thumbsup:
Re: 2000 jetta TDi
« Reply #127 on: October 05, 2015, 11:12:16 AM »
fired right up this morning without 8 seconds of cranking.
Re: 2000 jetta TDi
« Reply #128 on: October 07, 2015, 12:19:10 AM »
power steering high pressure hose changed
exhaust welded up
tire pulled and patched.
unit is 100% ready for winter.  still looking for a good deal on some snows maybe.
Re: 2000 jetta TDi
« Reply #129 on: October 07, 2015, 12:07:27 PM »
What size? I bought some 195/60/15's foor a car that is now in Texas.  Brand new
« Last Edit: October 07, 2015, 12:14:50 PM by matt »
Re: 2000 jetta TDi
« Reply #130 on: October 07, 2015, 01:00:48 PM »
thats the size i need
Re: 2000 jetta TDi
« Reply #131 on: November 01, 2015, 07:13:22 PM »
found hardline on rack leaking.  pulled hard line and cleaned and soldered up the pin hole haha    fuck you VW
Re: 2000 jetta TDi
« Reply #132 on: November 24, 2015, 12:05:26 AM »
back on daily duty from wonder down
http://rochester.craigslist.org/wto/5329756403.html
need!
Re: 2000 jetta TDi
« Reply #133 on: November 24, 2015, 01:07:59 PM »
home run
tires are mint and like new!  140$ delivered to shop! steal!
Re: 2000 jetta TDi
« Reply #134 on: November 27, 2015, 06:45:48 PM »
snows swapped over!
