Author Topic: Trailers...for the normal man  (Read 20495 times)
Re: Trailers...for the normal man
« Reply #60 on: April 05, 2012, 10:19:26 PM »
because now you need one!
thats how it works.
« Reply #61 on: April 23, 2012, 12:15:06 PM »
want to rent to own mine?  It is not officially up for sale yet but I am not using it anytime soon.  Maybe a little big for what you are looking for.   I want to make sure the enclosed is all set to go before I sell the open one.
We can talk at the meeting if you want.
« Reply #63 on: May 25, 2012, 04:43:51 PM »
you can buy that brand spankin new for $2699
« Reply #64 on: May 25, 2012, 04:49:42 PM »
But it comes with 6 sets of D-rings!?  ::)
...haven't priced new, sorry...
« Reply #65 on: May 25, 2012, 07:17:12 PM »
With the d rings maybe it's worth it :)
« Reply #66 on: May 25, 2012, 07:46:38 PM »
i would not pay 1000$ for that pile
look at the spare tire caved in, it has BRAND new tires fora reason, the same reason the last trailer erok bought had brand new tires
the axles are bent and its a WHOPPED POS
Dont ever buy a used trailer with new tires.  #1 rule.
« Reply #67 on: May 25, 2012, 09:21:36 PM »
Once out of a hundred the alignment is still good but then the rims fail anyway :)
« Reply #68 on: May 25, 2012, 10:15:54 PM »
Hey mine did not have new tires I bent that axle all by myself! Lol
Went to rotate the extreme camber tire tonight and noticed that the only thing holding the u bolt to the plate is rust.  Nuts are completely disintegrated. That could of been bad.
« Reply #69 on: June 29, 2012, 08:39:11 AM »
Red from Rightcoast is selling his Toyota and trailer for $3500, you and someone should work a deal, Trailer has got to be worth $2k at least.
« Reply #70 on: June 29, 2012, 08:41:30 AM »
link?
« Reply #71 on: June 29, 2012, 08:42:48 AM »
I saw it on Facebook, no link.
« Reply #72 on: June 29, 2012, 08:45:24 AM »
5SPD
Dual Cases 2.28 gears in both
Front Axle - 5.29s, lock rite, 30 spline longs and inner hub gears
Rear Axle - IFS rear, 5.29s an spooled
PSC Hydro Assist Ram 1.5 x 6
GM P Series pump mounted using one of Pete's custom brackets.
Spares include open diff with 5.29s, rear driveshaft and a set of wing doors. I have some other stuff but that's all I can think of.
Also would come with 10lb CO2 tank and regulator, 48" farm jack and other recovery gear (strap, tree saver and snatch block.
Also have a Superwinch 9i with 85' of 3/8" rope
« Reply #73 on: June 29, 2012, 09:07:38 AM »
i saw that, sounds like a crazy deal for anyone to jump into wheeling.  it claims 13-14mpg towing with a v6 tacoma.   super light stripped down trailer, not sure its worth 2k, but i think he put tires on it last season
« Reply #74 on: June 29, 2012, 09:13:01 AM »
if the trailer is LIGHT  i would be interested if sombody wants to deal...
