Author Topic: U4 tire tech  (Read 73002 times)
CJ
Re: U4 tire tech
« Reply #30 on: July 20, 2015, 10:10:34 PM »
What about IV bags? Similar shape to Tire balls
Re: U4 tire tech
« Reply #31 on: July 20, 2015, 10:33:17 PM »
interesting idea cora but im sure not rated for any pressure and medical = 100X cost
forgot to mention ATV guys use the walmart balls thats where i got the info from.  but they do run in the 3-5 PSI tire range
jacel861
  • Full Member
Re: U4 tire tech
« Reply #32 on: July 20, 2015, 11:24:31 PM »
Probably not. We need to find the most HD smooth rubber anythings that we can.
Implants.
Re: U4 tire tech
« Reply #33 on: July 20, 2015, 11:36:12 PM »
Tire Boobs         8)
Re: U4 tire tech
« Reply #34 on: July 20, 2015, 11:36:25 PM »
too heavy
walmart kick balls are the only way to go at less than a 1$ each from distributor
or from the pirate, after reading 20 lame threads about bs search fucker
This stuff is old as shit.
Where I come from, smugglers filled their armored 4x4 tires with 15/20 bicycle tubes. When the cops shot at the tires the bullet would kill just a few, the other tubes would keep the tire from collapsing.
Re: U4 tire tech
« Reply #35 on: July 20, 2015, 11:46:31 PM »
I could see innertubes working
CJ
Re: U4 tire tech
« Reply #36 on: July 21, 2015, 10:48:37 AM »
Tire Boobs         8)
I could totally market that!
Re: U4 tire tech
« Reply #37 on: July 21, 2015, 11:04:18 AM »
if someone gets a design I'm sure Ryan can find a cheap manufacturer.
And it shouldn't be too hard to get someone to draw a boob shaped bag in cad.
Just out of curiosity, doesn't anyone use a mid-density foam for this? seems that it would be better than pneumatics. I'm not an expert by any stretch, but it would seem that a little goop to adhere foam to rim or tire would prevent most of the tire ball throwing issues. And I'd think the foam would last a bit longer as it wouldn't really care about punctures. Moisture could be an issue though...
Re: U4 tire tech
« Reply #38 on: July 21, 2015, 11:11:14 AM »
heat / abraision / wear  with foam.
ATV guys tried Pool noodles, dust in miles on flat.
weight of a foam that can support 25psi is also way to heavy
http://www.hedstrom.com/products/balls-2/hedstrom-playballs
Re: U4 tire tech
« Reply #39 on: July 21, 2015, 11:18:36 AM »
Re: U4 tire tech
« Reply #40 on: July 21, 2015, 08:11:51 PM »
Did you check alibaba?
Re: U4 tire tech
« Reply #41 on: July 21, 2015, 09:55:36 PM »
Shipping from US?
