Author Topic: beer running wonder  (Read 10296 times)
Re: beer running wonder
« Reply #15 on: April 14, 2015, 02:14:19 PM »
Burn it!
« Reply #16 on: April 14, 2015, 03:53:44 PM »
this thing is KOH road trip ready
« Reply #17 on: April 14, 2015, 05:21:08 PM »
This is one sweet machine!
« Reply #18 on: May 03, 2015, 03:37:26 PM »
fixed, maybe?
took it to the store a week or so ago to see what would happen, ran fine there died twice on way home but started right up to drive home. picked up a cps and a instrument panel at j&j, xj's are getting scarce there now. panel didnt work right ,may not of been compatible, from a 2000 mine is a 98. so i cleaned the contact points on mine and so far so good, guages work every time since. replaced the cps yesterday, started up and let it run it eventually died once warm and didnt start again, got it running this morning eventually but died, pulled the iac, dirty as hell ,cleaned it and has been running fine just driving around the block last 20 minutes with no issues and no cel. $50 to throw some plugs ,wires,cap and rotor at this thing may do it in a week
« Reply #19 on: August 27, 2015, 03:15:00 PM »
$150 and this thing has a shiny new windshield thanks to L&m auto glass, I use to work at a pizza shop with the owners years ago. Got some brake pads and a obd2 scanner should be here today and inspection ready
« Reply #20 on: August 27, 2015, 11:01:52 PM »
obd2 scanner tool doa ,will not connect to ecu's in jeep or truck or in multiple apps and i got torque pro
« Reply #21 on: August 27, 2015, 11:57:45 PM »
did you pair and set it up.... i remember there were some non intuitive boxes that needed to be checked the first time i got mine to work
« Reply #22 on: August 28, 2015, 08:09:16 AM »
everything is connected, the blue car icon keeps flashing and under the adapter staus page everything is green checked except the talk to ecu ok
« Reply #23 on: August 28, 2015, 08:29:23 AM »
this thing has plugged in and passed NY inspection before?
« Reply #24 on: September 09, 2015, 11:21:51 AM »
New pads and rotors on the front of this thing along with recycled shocks from Carter St abandoned xj, got my new ob2 scanner, finding codes for tyranny prnd which I'm guessing is bad nss, which I'll swap a spare I have in, airbag light is on but no code ill just pop the dash bulb out and she will be inspection ready
« Reply #25 on: October 26, 2015, 06:13:37 PM »
new battery and ebay nss unit, still throwing codes for nss and cps who knows why. worked this weekend cutting the rocker rot out and replacing, this unit has a 700 mile round trip planned this weekend
« Reply #26 on: March 04, 2016, 09:56:56 PM »
brought it in for a inspection today,failed, computer in not ready mode gotta drive it around a bit and have 10 days to bring it back
« Reply #27 on: March 05, 2016, 05:51:52 PM »
my code reader shows emissions monitor status for this.  worth the 3$ to pay for the pro version of tork.  failure to set emissions monitors will not throw a CEL but will not pass plug in.
« Reply #28 on: March 05, 2016, 07:53:38 PM »
i have the torque pro, where will it say it its emissions ready
« Reply #29 on: March 06, 2016, 04:01:24 PM »
it may be a custom field you have to add. its the 4th page on mine.  emmissions readiness s/DTC
