Author Topic: Saint Michael (was: Big Things in Eagle Land)  (Read 44166 times)
Re: Big Things in Eagle Land
« Reply #75 on: March 27, 2012, 05:14:28 PM »
Where's my M4 patch?  I want an M4 patch!
Re: Red (was: Big Things in Eagle Land)
« Reply #76 on: April 02, 2012, 11:45:17 AM »
Finished the headlights in this last night, and replaced an alt belt too.  Turns out a little squeal turns into a belt eater when you put 100% load on an alternator.
Now I'm out of excuses to not get it inspected so I need to get that taken care of. Should get an alignment too, so I guess it'll wait until my trailer is cleared off or I con someone into giving me a ride back from Scotty's.
« Reply #77 on: April 10, 2012, 11:50:40 PM »
Just dropped this beast off at Scotty's for align & inspect. Need to remember to call them ASAP in the morning to let them know what the strange AMC in the lot is there for. No voicemail on the shop line nor after hours drop slot for a note that I found.
Re: Saint Michael (was: Big Things in Eagle Land)
« Reply #78 on: April 11, 2012, 03:57:25 AM »
I sent Paulie a text for you
« Reply #79 on: April 12, 2012, 02:22:05 PM »
i just passed a peice of crap like this one with a monster jam hat on the dash and a blue sticker
« Reply #80 on: April 12, 2012, 02:45:21 PM »
Lol
« Reply #81 on: April 12, 2012, 03:29:13 PM »
hahahahahaaa
« Reply #82 on: April 12, 2012, 04:04:34 PM »
Love it
« Reply #83 on: April 12, 2012, 05:55:27 PM »
Guess the alignment is fighting a little or taking time or something. Said its 3/4 done, on the rack now...
« Reply #84 on: May 12, 2012, 06:19:31 PM »
Not rolled
« Reply #85 on: May 12, 2012, 06:21:33 PM »
Just used.
That was my only stuck. Didn't make one other climb. I think the tranny mount is broken. Need to check that before the next Offroad excursion.
Low range and 33s may be in an Eagle's future. The "local wheeler"?
« Reply #86 on: May 12, 2012, 06:38:04 PM »
Ohhhh boy
« Reply #87 on: May 12, 2012, 07:16:58 PM »
If I'm not cutting within a day of having an idea chances of execution are slim. Speaking if, How's your RoadRanger swap going?
« Reply #88 on: May 12, 2012, 08:55:19 PM »
I am looking for a overdrive 6 speed so I don't have to use my gear vendor. The problem is my truck still works so that makes me procrastinate big time
« Reply #89 on: September 17, 2012, 12:24:41 AM »
Tried to fix temp gauge last week. Wire was disconnected, hooking it up made the gauge move a tiny bit. Swapped sensor - no change.
Need to check engine ground. Could be bad cluster too. Fuel gauge is jumpy too, I always assumed sender. Should swap in the parts car cluster and see what it does.
MPG are falling through the floor. Every tank worse than the last. Down to 10.9 last fill, uncorrected for the tires (probably ~10% off?). Bet the cat is clogged. Some pieces were in the muffler when I changed it.
Still need to fix the tranny mount as well. Not a listed part anywhere so I'll have to make something work.
