Author Topic: SOLID ORDER  (Read 8478 times)
Re: SOLID ORDER
« Reply #15 on: September 17, 2013, 05:02:16 PM »
http://www.polyperformance.com/shop/Synergy-Suspension-D44-D60-Drive-Gears-p-61.html
Says it allows the drive gear to be removed while still having the cap installed. Sounds like the way to go... Donno if Solid ones are the same. Those are a lot cheaper too...
Re: SOLID ORDER
« Reply #16 on: September 17, 2013, 05:03:15 PM »
on the solid site they have a "removable" slug option for 20$, wonder what that gets you
i'll try the removable option
Re: SOLID ORDER
« Reply #17 on: September 17, 2013, 06:18:23 PM »
D60 cover please
Re: SOLID ORDER
« Reply #18 on: September 18, 2013, 07:57:25 PM »
bump
Re: SOLID ORDER
« Reply #19 on: September 18, 2013, 08:16:30 PM »
How often do you order?
Re: SOLID ORDER
« Reply #20 on: September 24, 2013, 09:11:06 AM »
every couple months usually
last call? ordering tomorrow
Re: SOLID ORDER
« Reply #21 on: September 24, 2013, 10:33:50 AM »
i want those flanges.
can you ask about the "removable" option, if you dont mind. i cant find any info on that online...you can make an executive decision if they sound good. schrong is top priority.
Re: SOLID ORDER
« Reply #22 on: September 25, 2013, 04:32:45 PM »
"It allows you to remove the slug.  They are also better for full floaters as they won’t loosen up, since the cap isn’t bolted to the slug."
Re: SOLID ORDER
« Reply #23 on: September 25, 2013, 04:34:32 PM »
So... Remove cap, pull slug, reinstall cap? Sounds good to me. Not now, but in the future.
Re: SOLID ORDER
« Reply #24 on: September 25, 2013, 04:41:39 PM »
must just have a little slug within the main one.
that sounds good. i want those.
Re: SOLID ORDER
« Reply #25 on: September 25, 2013, 04:58:29 PM »
ill ask tonight at meeting if anyone else wants in, and get prices / send order tomorrow.
Re: SOLID ORDER
« Reply #26 on: October 06, 2013, 02:28:38 PM »
When's this stuff coming in?
Re: SOLID ORDER
« Reply #27 on: October 07, 2013, 02:39:31 PM »
should be mid-end this week.
Re: SOLID ORDER
« Reply #28 on: October 10, 2013, 10:30:09 AM »
Pending everything arrives as requested: here is the break down
Ryan (1) 60 cover 60$   PAID
Mike (2) 60 covers 120$ +205 seal kit 30$ - plugs 60$ + tent thing = 100$  PAID
Troy (1) 60 cover 60$
Spenser 35sp drive slugs with remove 180$
Harrison 35sp drive slugs with remove 180$
Smike (3) 30 covers 180$ (2) 60 covers 120$ (1) 44 cover 60$ = 360$
saved 250$ (deflated from combined shipping address)
solid site shows each cover at 65$ plus 17$ shipping
not too bad.
« Last Edit: October 22, 2013, 10:01:24 AM by M4wdFab »
Re: SOLID ORDER
« Reply #29 on: October 10, 2013, 10:31:19 AM »
Great, I need to replace the fluid in the front diff, its leaking a mix of water and gear oil all over my floor.
