Author Topic: The nimble, lightweight crawler  (Read 27490 times)
Re: The nimble, lightweight crawler
« Reply #90 on: April 03, 2014, 09:09:15 AM »
brake light switch is bad and the flashers were both bad. multifunction switch was fine.
I have turn signals now but no brake lights. Both tail lights are at least a little broken, it needs the in-tailgate plus side marker setup like the dakota got or beefy tail light guards and a dovetail.
I think it's good to have a door slammer with glass and heat that can hit the street. ish.
so:
- trans temp gauge, deep pan. already have.
- front axle forward ~3/4-1". whatever the frame side track bar mount will allow for. Aside from swaybar delete I shouldn't need to do anything as long as the driveshaft has enough slip, and I'd bet it does.
- bob the back of the frame behind the spring hangers and get rid of the monster hitch plow plate thing.
- fix HVAC blower and temp controls, maybe fix AC if it doesn't need much. have all the spares I could need.
- AC condensor as addl trans cooler?
- weld rear
- I'd rather lock than weld the front for steering, handling, streetability. I'll break the stock shafts if it's not left open. Maybe swap the built Ford axle from the Dakota? Gear the truck to 5.13? Probably easier and cheaper than CAD delete plus set of shafts.
- mild boatside, replace rockers and floors, solid mount cab
- fuel cell in the bad, flat belly.
whenever I get around to it.
« Reply #91 on: April 03, 2014, 09:16:16 AM »
thats sounds like a whole lot of work...
« Reply #92 on: April 03, 2014, 09:21:27 AM »
it all comes after a dakota and eagle and jetta part/scrap-out too, and thoughts of bathroom and kitchen work, and cabinets in the front room... I have spring cleaning and projects on my mind.
« Reply #93 on: April 03, 2014, 09:22:52 AM »
Dont forget ZJ, another eagle, another eagle, tow rig work, trailer work, woman things, and blah blah blah........
« Reply #94 on: April 03, 2014, 09:23:32 AM »
dog and dog and dog...
« Reply #95 on: April 03, 2014, 09:39:14 AM »
I don't need a ZJ
« Reply #96 on: April 03, 2014, 09:40:36 AM »
« Reply #97 on: April 03, 2014, 09:42:27 AM »
scrap everything but tow rig & 3 trailers, build buggy!
« Reply #98 on: April 03, 2014, 09:42:42 AM »
I know.
I've been thinking about that - I think I want to shake down the TDI/Toy setup in an Eagle, and put it in the WJ when I'm happy with it and ready for another hurdle of electronics.
« Reply #99 on: April 03, 2014, 09:43:59 AM »
Buy buggy, scrap wedgie. Forgot about that item. Need to take pics and post it unless there's any further interest from here.
« Reply #100 on: April 03, 2014, 09:45:13 AM »
TURN IT OFF!
« Reply #101 on: April 03, 2014, 09:45:45 AM »
how's the toyota?
« Reply #102 on: April 03, 2014, 09:47:37 AM »
let me know when you want a showing.  Needs to be DRY if you want to rip it around, but you know how it drives :)
needs seats bolted in, and new LED light upgrade installed, else she is 100% race ready minus numbers.
« Reply #103 on: April 03, 2014, 09:54:51 AM »
how's the toyota?
100% assembled, 20 minute running, wheeling machine neatly tucked away in the garage :)
« Reply #104 on: April 03, 2014, 10:13:48 AM »
and btw I was not kidding about taking both to alpco after twisted toys ;D
