Author Topic: Tony's 05 Rubi  (Read 17507 times)
Re: Tony's 05 Rubi
« Reply #15 on: February 20, 2012, 12:05:29 PM »
Sweeeet
Re: Tony's 05 Rubi
« Reply #16 on: February 22, 2012, 01:48:22 AM »
done minus 4 bolts that need to be put in the long arm brackets that the fine thread nuts disappeared.   looks good rides good.
Re: Tony's 05 Rubi
« Reply #17 on: February 22, 2012, 08:16:29 AM »
Way to go. M4wd doesn't mess around.
Re: Tony's 05 Rubi
« Reply #18 on: February 22, 2012, 09:20:39 AM »
skyjacker 5" long arm kit (coils, links, bump stops, shock relocation brackets, shocks, arms, ect.)
1" body lift
MORE motor mount lift
JKS rear track bar
JKS front track bar
new SS flex lines extended
Currie HD steering
TW rear shaft
Upper rear adjustable links
Fixed rear pinion CLUNK
TCase linkage Relocation bracket installed
Temp trans lift mount bracket fabricated
Re: Tony's 05 Rubi
« Reply #19 on: February 22, 2012, 09:23:07 AM »
pics or it never happened...
Re: Tony's 05 Rubi
« Reply #20 on: February 22, 2012, 09:39:41 AM »
actually dont have many pics on this one, was busting ass most of the last 3 days!
Re: Tony's 05 Rubi
« Reply #21 on: February 22, 2012, 09:40:24 AM »
I'll vouche for M4wd. I was there and saw it at two different points. And I have got to say that Currie steering is the bomb.
Re: Tony's 05 Rubi
« Reply #22 on: February 22, 2012, 03:44:39 PM »
What did you do with the issue with the sway bar and steering issue
Re: Tony's 05 Rubi
« Reply #23 on: February 22, 2012, 03:49:46 PM »
no fix, when you go full extention both sides at once, it crashes to stock bracket.
shock limit helps, but its just plain not designed to fit.  lift didnt change it, as was installed before.  Currie guy1 says pinion is cranked up and caster angle is way off.  i measured 7.4 degrees, spec is 7 degrees. Currie guy2 says pull front axle in, or cut the bracket off.
they obviously don't know jack about anything and just sell stuff.
Re: Tony's 05 Rubi
« Reply #24 on: February 22, 2012, 05:15:31 PM »
Currie guy #2 is correct.... those are pretty much your options
Re: Tony's 05 Rubi
« Reply #25 on: February 22, 2012, 11:11:45 PM »
skyjacker said 29.25 we  were at 28.5 already on the front lowers with stock uppers
Re: Tony's 05 Rubi
« Reply #26 on: March 05, 2012, 10:47:13 PM »
coming back saturday for some suspention tweaks and a full custom tummy tuck 3/16" skid!
siiiiik!
Re: Tony's 05 Rubi
« Reply #27 on: March 11, 2012, 12:41:18 AM »
Finished the skid plate on this today, this thing is sick!
Re: Tony's 05 Rubi
« Reply #28 on: March 11, 2012, 09:28:15 AM »
Re: Tony's 05 Rubi
« Reply #29 on: March 11, 2012, 07:51:14 PM »
you people not on the book of faces! just give in!
