Author Topic: Some Dumpbus Updates  (Read 91286 times)
« Reply #345 on: April 08, 2013, 10:53:52 PM »
Mostly stripped the engine bay. Turbo I almost smoked :( cold side blades making housing contact.
Still need to pull the big stuff (turbo, mani, lines, valve cover, sticks, pump, tappet cover, cam, case, head, brake master & booster), but all accessories and easy stuff is off, in the trailer behind the Eagle
Re: Some Dumpbus Updates
« Reply #346 on: April 09, 2013, 09:23:08 AM »
turbo bits cause of motor failure?
« Reply #347 on: April 09, 2013, 11:12:36 AM »
no way, it's not shelled. I didn't look super-closely, but the case isn't obviously scarred. it was just starting to make contact.
« Reply #348 on: April 09, 2013, 08:54:11 PM »
Well there's your problem right there!
« Reply #349 on: April 09, 2013, 08:59:21 PM »
Probable cause?  Head gasket failure?
« Reply #350 on: April 09, 2013, 09:57:06 PM »
Head gasket is perfect. High egt during wrong cam time caused top of piston to crack to top ring land. Loss of compression caused rich mixture and melty edges.
My reasoning anyway. The knock it picked up was probably piston slap. It's awfully loose in the bore.
« Reply #351 on: April 10, 2013, 06:02:04 PM »
Wow
So how do I make that not happen?
« Reply #352 on: April 10, 2013, 07:37:09 PM »
Not run 1500+* egt
« Reply #353 on: April 14, 2013, 12:10:11 PM »
There's a really short list of parts left to remove from this guy. Trailer needs some reorg to make room for the larger items and body parts.
Yesterday was a waste as far as teardown, but I might still be "done" today if I commit. Weather looks good, and the rest of the week looks damn busy.
« Reply #354 on: April 15, 2013, 12:08:29 AM »
Got lots of fuel out but both tanks are still in. dash out, body stripped...
Driveshaft, trans, engine, tanks. Then it'll go on the trailer, and axles need to be freed. birthday party tomorrow and dinner weds. Hopefully get it on the trailer Tuesday night and scrapped weds.
Trailer is pretty damn full. I think the body parts may go on CList.
« Reply #355 on: April 16, 2013, 08:48:53 AM »
Rain or shine tonight, it's time. I want tanks and drivetrain out tonight. Axles free would be nice too. May pull over to M4 for some plasma use. Ive got a guy who wants a body mount off the cab, and the  rear shackle mounts are wanted too.
« Reply #356 on: April 16, 2013, 09:00:35 AM »
M4 is not in operation tonight :(
will be an hour west for family stuff.
« Reply #357 on: April 16, 2013, 09:09:21 AM »
your poor neighbors...
« Reply #358 on: April 16, 2013, 09:09:52 AM »
10-4. May sit on the trailer for a day or two then depending how my cutoff wheel supply and stamina is.
« Reply #359 on: April 16, 2013, 09:10:03 AM »
